Telefunken d48u300n4cw with sound and picture but no backlight
  • vigorcent
    • Jul 2021
    • 15
    Re: Telefunken d48u300n4cw with sound and picture but no backlight
    Well now this is really strange... I didn't see that, thanks for pointing that out.
    No, it is not a burned component, but there initially was one. This is the power supply I bought from the replacement store. In fact, the component wasn't removed, but moved to the left. I'll post a picture for comparison.
    On the left is my old psu that was originally built into the newly bought TV. This psu didn't show the initial backlight flash (and voltage peak at led pins) when turning on the TV.
    On the right is the replacement psu I bought last week.
    This means that pin 6 is connected to the MP3394 and not pin 7, whereas pin 7 leads to led- of the upper led strip group and pin 6 doesn't even have a wire. I need to leave the house again. When I'm back, I'll have a look if I find anything else that's different.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      So the power supply on the left is the original one that came with the tv when it was new.
      If that is the case then you would need to alter the replacement power supply so that it matches you original power supply.
      As you say the boards do not match and the connection from pins 8 & 9 of the MP3394 do not go to the same pin of the led connector and that is probably what is at fault.
      • vigorcent
        • Jul 2021
        • 15
        I will try to move this component and will let you know tomorrow.
        • vigorcent
          • Jul 2021
          • 15
          It's working now! Only thing is that there is a loud buzzing sound when I'm using specific picture presets or at low backlight settings, but It will do for now.
          Thank you so much for your help, dick_barton! I wouldn't have found the issue on my own.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            No; it was a team effort and youdid spot the cross over 0 ohm resistor going to the wrong led connector pin.
            Do not forget to lower the backlights down as low as possible to provide a longer lifespan for your leds.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • Zonzi
              Telefunken L70 speakers, one has a nasal sound with less bass
              by Zonzi
              Hi everyone !
              Once again I have an issue with old stuff I found for cheap, guess I have a taste for these.
              I bought these two Telefunken L70 speakers for 20€ (https://www.radiomuseum.org/r/telefu...r_box_l_2.html), and they are in a superb state, component-wise. The box is scratched but I couldn't care less, I'm interested by whether it works or not.
              They do work, and have a really nice sound, but one of the two has a problem with its 8" woofer. It's got practically no bass, and the mids are really pushed...
              05-31-2023, 12:34 PM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:30 PM
