Hey there everyone,
so I was trying to repair my grandpas TV, but I came to my limits. I only have basic knowledge and
I'm still a novice, but it actually was kind of fun and I learned a lot this far.
As this forum helped me already, I finally decided to make my own thread and I hope someone of you can help me here.
So first, the models are:
TV: Telefunken d48u300n4cw
PSU: Vestel 17ips20-r9 23253538
Mainboard: Vestel 17mb100
I don't really know which number on the mb is relevant for further specification, so I will attach
some pictures with all the numbers.
What is the problem:
I do have sound and I can also see the menu while using a flashlight, but there is no backlight at all.
In the beginning when I turned on the TV there was a very short flash, but after a while this flash disappeared.
What I did:
First I checked for bad caps and as far as my amateur eye can see, they all seemed to be ok. Then I opened the panel and checked every LED. There was one single LED not lighting up, so I thought
that I have found the culprit. After replacing the strip however, nothing has changed. So I bought a
replacement PSU and replaced it (from here on, I will just call them "old" and "new" PSU). Now the initial flash when starting the TV is back, but still the same problem, so I guess it could be the main board?
It was very hard to find the schematic for my PSU model. The best I could find was this from another thread:
https://www.badcaps.net/forum/attach...5&d=1603209027
At the very last page, it says for the CN4
1) +24V_AUDIO
3) ST_BY
5) BL_ON-OFF
7) PWM_DIM
9) +5V_STBY
11) +12V_STBY_MB
2) 2D-3D OPS.
4) GRND
6) GRND
8) GRND
10) +12V_STBY_MB
12) +12V_STBY_MB
Here is what I measured (first value: mb not connected, second value: mb connected and TV on, third value: mb connected and TV off):
1) 24.4V ... 24.8V ... 0V
3) 0V ... 0V ... 2V
5) 0V ... 3.2V ... 0.2V
7) 2V ... 2.6V ... 0V
9) 0V ... 0V ... 0V
11) 11.9V ... 11.8V ...11.9V
2) -1.7V ... 0V ... 0V
4) GRND ... GRND ... GRND
6) GRND ... GRND ... GRND
8) GRND ... GRND ... GRND
10) 11.9V ... 11.8V ...11.9V
12) 11.9V ... 11.8V ...11.9V
Also, there are two "empty" pins on the main board between pin 9 and 11, as well as 10 and 12 which show 11.8V (turned on) and 11.9V (turned off).
There is one thing to mention: Whenever I measure pin 9 (+5V_STBY) on the new PSU when the TV is on, my multimeter shows 0.5V, and it quickly drops to 0V.
The schematics I posted above show that this pin leads to Q212 but when checking the PCB it seems to not be connected to anything on this PSU model.
So my guess is that the main board is actually managing this (and possibly the backlight as well?).
Then I also measured the pins leading to the LEDs (see attached pictures).
When I turn on the TV with the new PSU and the flash occurs, the voltage peaks at about 140V for the red and brown cable and 60V for the orange and black cable.
They then slowly decrease to
orange: 8.1V
red: 78.2V
black: 7.8V
brown 78.2V
within about a minute and then steadily stay there. When I turn the TV off, orange and black drop to 0V and 1V in about 30 seconds. Red and brown slowly drop to 0V in about 5 minutes, while black rises to 1.7V.
The old PSU does not peak to 140 and 60V (because there is also no flash) but immediately stay at about 79.2V for red and brown, 8.8V for orange and 3.9V for black.
All measurements for the LED pins as well as CN4 were taken by placing my black lead on the chassis and red lead on the pins.
My questions right now are:
1) Even if the PSU is not responsible for the TV having no backlight, there must be something wrong with my old PSU, right? I want to know this,
because otherwise I can send the new one back within 14 days and save some money.
2) I do get 3.2V for the BL_ON-OFF pin and 2.6V for PWM_DIM pin, but how do I find out what is needed here?
3) I don't get any voltage at the +5V_STBY, but as far as I understand, the main board is responsible for this. Am I right with this assumption?
4) What would be the next step? Any ideas?
Any help is much appreciated, and sorry for the long text. I hope I didn't write too much unnecessary stuff.
As I said, I just want to repair my grandpas TV if I can and learn as much as possible along the way.
What I did:
1) +24V_AUDIO
3) ST_BY
5) BL_ON-OFF
7) PWM_DIM
9) +5V_STBY
11) +12V_STBY_MB
2) 2D-3D OPS.
4) GRND
6) GRND
8) GRND
10) +12V_STBY_MB
12) +12V_STBY_MB
3) 0V ... 0V ... 2V
9) 0V ... 0V ... 0V
orange: 8.1V
red: 78.2V
black: 7.8V
brown 78.2V
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
