Vestel 17IPS20 R6
  • rigeback
    • Mar 2011
    • 421
    • Malta
    Vestel 17IPS20 R6
    Got this 40" TV off the tip and the power board has a problem, previous attempts have been made with the replacement of the thermo resistors.
    Main filter caps have 330V although It seems Q211 has a problem as the outer pins are having continuity, caps seem okay but I suspect there is a shorted resistor some where??
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vestel 17IPS20 R6
    The best way to test Q211 is to take it out of circuit. Also check all the components around it as shown on the schematic.
    • rigeback
      • Mar 2011
      • 421
      • Malta
      Yes I been trying all the small caps around most components sre good.
      C214 / C225 is shorted on board, how many Uf for a 50 volt cap?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I don't know how close the schematic matches you power supply and the values given on the schematic do not always tally with what's on the board
        1uF = 1000nF so 1nF = 0.001uF
        Measure the resistance between pin 2 and 3 of U202, Suspect it may be short circuit.
        • rigeback
          • Mar 2011
          • 421
          • Malta
          Off board C214 is Ok so will have to reinstall.
          U202 between 2/3 pins reads 1 so no short although my M/Meter is very basic for this work.
          I am going to remove Q211 is it possible to remove without the heat sink?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I doesn't look like. Use desoldering braid to remove the solder from the heatsink legs.
            • rigeback
              • Mar 2011
              • 421
              • Malta
              Yep jimmied it off and I don't it is the problem after testing it with my basic M/Meter.
              Some thing else on the board is causing this short???
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                So with it off the board where is the short to ground on the board. Is it where the Gate or Source or Drain is connected?
                • rigeback
                  • Mar 2011
                  • 421
                  • Malta
                  Gate / Source shorting to ground pins 3/4 U202
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Have you checked D510 & D511 for short circuit using your meter set to diode mode. TV set powered off. I would also check transistor Q215
                    • rigeback
                      • Mar 2011
                      • 421
                      • Malta
                      Q215 is the Fet that I removed? Q211 is printed on the topside? Confusing this board.
                      D510 seems ok although not sure if its marked Q510 as prints not so clear. D511 still looking, I see it on the schematic but not board, I must getting old!
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Q211 would be the mosfet attached to the heatsink.
                        Post some photo's of the area of the board around Q211, top and bottom to see what components are fitted on the power supply and match the schematic.
                        • rigeback
                          • Mar 2011
                          • 421
                          • Malta
                          Not sure if these close ups of the area will help, unless the schematic is not for this board?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Check D201 as per attachmnent
                            • rigeback
                              • Mar 2011
                              • 421
                              • Malta
                              D201 and D214 Check OK
                              • rigeback
                                • Mar 2011
                                • 421
                                • Malta
                                D213 seems to be shorted but it could be the circuit
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  In the schematic D213 is in parallel with a 10 ohm resistor so the only way to check it is to lift it out of circuit but remember which way around it was in before removing it.
                                  • rigeback
                                    • Mar 2011
                                    • 421
                                    • Malta
                                    Looking at the board again!
                                    D101 has 330V on both sides, seems strange that a diode that a diode is in place?
                                    I'll take off board although on board it checks normal
                                    • rigeback
                                      • Mar 2011
                                      • 421
                                      • Malta
                                      Some new findings D214 and D215 have 240V and at CON4 12V,
                                      I replaced the FET and D101 as they checked OK off board.
                                      I am thinking is it a matter of PS_ON not being activated or is a way to have PS_ON activated always as in other TV's?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        D214 will not have 240V on it. You need to use hot ground. Connect your black meter lead to the negative leg of C105 carefully and make certain it does not touch anything else. Then connect your red meter led to D214 and measure again.
                                        You say you have the 12V on CN4. Do you also have +5V at CN4, Pin 9 and if not is Q212 transistor soldered on the power supply?
                                        It would be interesting to know what all the pin voltages are for CN4
                                        • psdavid65
                                          Toshiba 40L1333DEV Vestel 17IPS20
                                          by psdavid65
                                          Quick Question Please.
                                          Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
                                          All other components on this vestel board have valid readings except for this U202 IC.
                                          09-21-2023, 12:29 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • ray14324
                                          Telefunken LED TV with no standby linght equipped with Vestel 17IPS20 PSU
                                          by ray14324
                                          Searching the forum revealed loads of issues with this type of power supply board however I could not find a solution to my issue from them. Excuse the "another Vestel" thread
                                          The full story was: my Telefunken TV did not have a standby red light after of series of power outages in a couple of minutes. Sadly in my rural city the only technician that fixes TV's is away these days as I cannot reach him by phone. I want to try to have a go at it (with the internet's help).
                                          Reading into this symptom the general consensus was that...
                                          08-31-2021, 07:55 AM
                                        • alltvrepairs
                                          Vestel 17IPS20 power supply Q301 runs too hot
                                          by alltvrepairs
                                          Have just repaired this power supply after 4.7pF 2kv cap burnt.
                                          Replaced the following:
                                          U300 FAN6300
                                          Q301 8N60C
                                          R321 10R
                                          R311 10R
                                          C312 47pF 2KV
                                          All Supplies are now fine and TV works great however noticed that the Mosfet is running too hot that barely can leave finger on heatsink for a couple of seconds. I have left TV ON for 18Hrs straight and still works but I know something is not right.
                                          Usually a faulty snubber circuit causes this issue. Any known remedies for this common power supply?
                                          05-02-2022, 01:46 AM
