Vestel 17IPS20 R6
  • rigeback
    • Mar 2011
    • 421
    • Malta
    Re: Vestel 17IPS20 R6
    Yes 240mV sorry didn't notice, Q200 and Q207 have 5V
    • rigeback
      • Mar 2011
      • 421
      • Malta
      16V on CN4 but no 5V, Q212 is soldered back on the board
      • rigeback
        • Mar 2011
        • 421
        • Malta
        I was reading this from another post and my U202 has 14V pin 8 and pin 6 = 5V.
        The circuit that needs to be working is the one for U202/TR200, it supplies 12V_AC to get 12v_DC which supplies +12VCC_S which supplies Q212 and gives +5V_STBY
        TR200 also supplies VCC_MAIN, Q216 is a switch that controls VCC that supplies U300 etc. Q216 is basically controled by ST_BY from the main baord.
        So you need st_by ON signal from the main board to have VCC on U300
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          If Q212 is connected in circuit what are the voltages on the 3 legs?
          You said you had 12V on CN4 (12VCC_S) so U202 must be driving T200 for the secondary 12V AC to provide the 12VCC_S supply.
          What voltage do you have with the black lead of your meter connected to the negative leg of C105 and red meter lead connected to D215
          My current thinking is that you do not have standby being issued from the mainboard.
          Have you checked what voltage is on the standby pin CN4 - Pin 3 and does it change when you go in and out of standby.
          Can you post a photo of the underside where Q212 is located because I cannot see it in your photos in post #1
          • rigeback
            • Mar 2011
            • 421
            • Malta
            Confused as in the schematic the Mosfet is numbered Q211 and (Q215 BC858B) connects,
            anyhow 330V Drain and the rest 0V!
            CN4 has 12V but no 5V even when connected to the main board, in this case the the red light should come on if there was 5V.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              #26
              There is no 5V because I don't think Q212 is fitted to your board and it probably gets 5V from the mainboard.
              Can you post a photo of Q212 if it is fitted on the power supply and give the voltages on the 3 pins.
              Also can you give the pin numbers and voltages on all the pins of connector CN4
              • rigeback
                • Mar 2011
                • 421
                • Malta
                #27
                I re checked the voltages on all the pins and the max is 1.6V on pin 7 since it was reading MV. The rest of the pins are dead.
                Q212 is not fitted on this board although 5V is present close by at C214.
                • cheeky2
                  • Dec 2012
                  • 337
                  #28
                  A small point but you haven't stated what the issue is with the power board besides a short? What makes you think it's the power board at fault as from what you have stated no voltages have been taken of the output of the power board?
                  A more reasoned diagnosis would be to check the output voltages from the psu and establish what voltages are missing if any. If there any missing or low then trace the circuit back of that voltage and check the components that provide the output.
                  Poking and hoping strategy can help sometimes with obvious faults but reasoned diagnosis always wins.
                  • rigeback
                    • Mar 2011
                    • 421
                    • Malta
                    #29
                    In between house moves but still want fix the tv!
                    Since there are no out going Volts or incoming and I"m not sure if the main board is working I first need to by pass the ST_BY state by installing two parallel connected 470? 2W resistors.
                    Should the resistors be fitted on CN4 between Pin 1 and 3?
                    • rigeback
                      • Mar 2011
                      • 421
                      • Malta
                      #30
                      Since I'm getting 14V on R291 pin 8 0f U202 I think U202 (FAN6300) is faulty as pin 6 VDD is dead including the other pins, planning to order the part but could be easier getting a replacement board at this stage of the game.
                      • psdavid65
                        Toshiba 40L1333DEV Vestel 17IPS20
                        by psdavid65
                        Quick Question Please.
                        Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
                        All other components on this vestel board have valid readings except for this U202 IC.
                        09-21-2023, 12:29 PM
                      • France_53
                        Vestel tv, how to flip the image?
                        by France_53
                        Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                        05-12-2024, 05:22 AM
                      • ray14324
                        Telefunken LED TV with no standby linght equipped with Vestel 17IPS20 PSU
                        by ray14324
                        Searching the forum revealed loads of issues with this type of power supply board however I could not find a solution to my issue from them. Excuse the "another Vestel" thread
                        The full story was: my Telefunken TV did not have a standby red light after of series of power outages in a couple of minutes. Sadly in my rural city the only technician that fixes TV's is away these days as I cannot reach him by phone. I want to try to have a go at it (with the internet's help).
                        Reading into this symptom the general consensus was that...
                        08-31-2021, 07:55 AM
                      • worlor
                        Bad Vestel 17IPS20 : shortage, need help
                        by worlor
                        My Vestel television has stopped working.
                        After first diagnosys, the power board 17IPS20 R6 don't work (no 12V on output).
                        I have replaced :
                        • U300 FAN6300 -> completely blown up
                        • Q301 MOSFET FQPF8N60C
                        • C387 1uF Capacitor -> shorted
                        • C295 & C296 1uF capacitor -> to be sure
                        But with my multimeter, there is conductivity between VCC and GND on U300 and U202. I don't know why. Maybe a diode but i can't test these because of the short.
                        Can you help me to find the cause of the shortage ? have you any ideas ?
                        I attach...
                        11-08-2020, 06:47 AM
                      • alltvrepairs
                        Vestel 17IPS20 power supply Q301 runs too hot
                        by alltvrepairs
                        Have just repaired this power supply after 4.7pF 2kv cap burnt.
                        Replaced the following:
                        U300 FAN6300
                        Q301 8N60C
                        R321 10R
                        R311 10R
                        C312 47pF 2KV
                        All Supplies are now fine and TV works great however noticed that the Mosfet is running too hot that barely can leave finger on heatsink for a couple of seconds. I have left TV ON for 18Hrs straight and still works but I know something is not right.
                        Usually a faulty snubber circuit causes this issue. Any known remedies for this common power supply?
                        05-02-2022, 01:46 AM
