Sony KDL40EX501, won't power on, no standby light
  • macinjosh
    • Aug 2021
    Hello all,
    My Sony Bravia recently (after a storm) shows no red standby light at all. Taking it apart, I noticed that one of the ICs on the main board seemed to have a hole in it, so I replaced the main board.
    However, I still have the same problem.
    I've looked at the SONY technical flowchart for these models, but am stuck at what to do at this point. Here's what I've done:
    1. I've verified that the power supply board is getting 120v AC.
    2. Verified standby voltage, about 3V DC on pin 1 of the power supply.
    3. Verified about 3V DC on pin 2 (AC_DET_OFF, I think?).
    Here's where I lose clarity. Should I measure pin 3 of the power supply with the connector (to the main board) and its wires attached, or not?
    If I measure it with the connector off, I get 0V on pin 3. If I measure it with the connector and wires attached, I briefly get about 3V, but only for about four seconds, after which it goes to 0V. The whole time, I did not push the Power button at all.
    What should I look for next? Is it certain that the power supply board is bad?
    Thanks!
    Josh
  • lotas
    • Jan 2016
    • 4905
    • Russia
    Re: Sony KDL40EX501, won't power on, no standby light
    Power Supply Sony AZ1-L G2HE
    • macinjosh
      • Aug 2021
      Thank you, but I'm afraid the diagram by itself doesn't help me much. Can someone explain to me what to make of the situation I described, and what to do next?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        You could disconnect the power supply from the mainboard ( power to the set off) and connect a 1K ohm resistor between the STBY3.3V (Pin 1) and Power On (pin 3) and then power up the TV and check if the 12V and 24V supplies are present and correct.
          03-31-2024, 02:12 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • shovenose
          Christmas Light Power Supply Question
          by shovenose
          I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
          Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
          12-08-2023, 09:59 AM
