Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Hello everyone!
    Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
    Symptoms:
    1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
    2) TV does not appear to turn on
    3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
    4) "Power on" terminal on Power Supply has 3.26v
    5) "A13V" terminals have 12.9v
    6) Stand-by test jumper on Power Supply has 12.9V
    7) Optical audio jack on Main Board illuminates
    8) With stand-by light off a pulse is seen on the stand-by light when the "POWER" button is pressed on the remote but the TV fails to respond.
    9) A couple minutes after plugging TV in to AC outlet stand-by light turns back on, and does so on it's own
    10) With stand-by light on "Power on" terminal continues to have 3.26v
    11) With stand-by light on "A13V" terminals continue to have 12.9v
    12) With stand-by light on stand-by test jumper terminal continues to have 12.9v
    13) With stand-by light on optical audio jack on Main Board continues to illuminate.
    14) With stand-by light on a pulse is seen on the stand-by light when the "POWER" button is pressed on the remote, returns to solid illumination when the button is released and the TV does not turn on.
    15) If the TV is unplugged from AC power and plugged back in all of the above repeat.
    16) There is no change in symptoms with either or both LVDS cables detached from Main Board
    17) When main board connector is disconnected from the Power Supply the backlights illuminate and all the prescribed voltages are present.
    This appears to be a Main Board issue. Does anyone concur?
    I've found several Main Boards under $30.00 so I don't plan on troubleshooting it to component level, but I would perform other testing to confirm if needed.
    They call me......."threadkiller"
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be
    So the "Power On" signal does not toggle state when you press the remote to turn on the set. If not then it would appear to be a mainboard issue.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      That is correct, and the stand-by voltage never toggles between 7 and 13v.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        This TV has Main Board part# BN94-12873M. I just checked my parts stock and I have a Main Board part# BN94-12873C for the same model, just a different version. There is a slight variance in the panel part numbers between the 2 TVs.
        I wonder if it would hurt anything to use the C suffix Main Board to test the rest of the TV? I know this model is having panel issues and it would be nice to verify the panel works before ordering a Main for this.
        Does anyone have an opinion about substituting the C suffix board temporarily, and for testing purposes only?
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          Ok so I decided to install the 12873C board but DID NOT attach the LVDS cables to it.
          The stand-by light illuminated, and when I pressed the power button the TV turned on, the backlights came on full brightness, dimmed, came back up to full brightness and I got an audio prompt for TV set-up. I pressed the power button and the TV turned off normally.
          Now begs the question....do I dare hook the LVDS cables up to the Main Board?
          The previous owner said the TV was working normally when they turned it off and went to bed. The next morning they tried to turn it on and it presented with the symptoms I mentioned in the first post.
          I'm not so sure it's worth the risk to the screen or Main Board to attach the LVDS cables. I can't see the TV working fine with a good picture and the screen being short the next morning....although stranger things have happened.
          SO what do we think here folks....hook them up or just get a Main Board coming?
          • ikmpch
            • Jul 2020
            • 22
            Check the 12VDc supply on LVDS connector on main board. If present, it should be good to connect.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              Thanks for the reply on that ikmpch. I have a Main Board coming from New York so I think I will go ahead and wait until it gets here.
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                So the Main Board came in today. I installed it and the TV is now working great! The picture looks as good as it can for this model and there's no backlight/main diffuser issues far as I can tell.
                Thanks for everyone's input, I appreciate it!
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  Three days later and this TV is aces!
                  • Kaar3l
                    Samsung QLED QE65Q7FNAT only standby light
                    by Kaar3l
                    TV: Samsung QLED QE65Q7FNAT
                    PSU: BN4400940A
                    MB: BN94-12832K
                    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                    09-24-2024, 01:35 PM
                  • jasonbay13
                    Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                    by jasonbay13
                    picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                    am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                    12-01-2023, 09:55 PM
                  • Nicktronic
                    Samsung UN70NU6070F Standby Light flashes twice
                    by Nicktronic
                    Hey Everyone,
                    So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                    I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                    03-27-2023, 07:01 PM
                  • Jovica123
                    Samsung UE55AU8072U no standby light
                    by Jovica123
                    i have here Samsung UE55AU8072U no standby light.
                    Panel model : CY-SA055HGXY1V
                    Motheboard model : bn41-02844A bn94-16868V
                    When i press the power button,standby light turn on,after i release it immediately turns off.
                    Unplugged main board from power supply - BACKLIGHTS COME ON.
                    I think the motheboard is problem.
                    I fixed two TV with same mistake,but they were 6000-series,there was a problem with the contents of the w25q40 chip.
                    Here are all dumps : ic801(24c512),ic1603 and ic1604(25q40)....
                    12-10-2023, 09:21 AM
                  • Thierry Wolffenbuttel
                    Ps5 with bad standby voltages
                    by Thierry Wolffenbuttel
                    I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                    04-08-2024, 08:04 AM
