Samsung SyncMaster T200HD
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    Hi to all
    i have the above tv when s soon as I plug it in, the red led standby turns on for a while and goes off
    Does anyone know what it can be?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Samsung SyncMaster T200HD
    Open it up and check for faulty capacitors on the power supply.
    https://www.youtube.com/watch?v=z0ZFw9HyKbE
    https://www.youtube.com/watch?v=m0tI-4aAyVk
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      thanks for the answer sir
      in my case I do not have deformed inflatable capacitors
      should i take them out one by one and measure with the capacitance meter?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Post some photo's of your power supply. Someone may spot a problem.
        • R_J
          • Jun 2012
          • 9532
          Originally posted by Xristakis795
          Hi to all
          This could be normal, What happens after it is "plugged in" and you press power? Have you checked any voltages on the power supply plug going to the main board?
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            no the truth is that I have not measured trends yet
            The TV is of a friend of mine, it worked normally, we changed its position to check the antenna, we timed it normally and as soon as we put it back in its old position, it had a problem, the plug did not fit well in and from there and then it does that
            I do not know if when you plug in the specific model remains standby and then you have to press on to turn on
            I will try to measure trends and tell you about it
            I measure all the capacitors of the power supply and it was ok
              09-07-2024, 05:50 AM
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • soopacrucial
              Samsung Syncmaster 740BF repair
              by soopacrucial
              Hi folks,
              I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
              Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
              10-29-2024, 02:40 PM
            • ChristianBr01
              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
              by ChristianBr01
              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
              04-23-2025, 01:48 AM
            • Kaar3l
              Samsung QLED QE65Q7FNAT only standby light
              by Kaar3l
              TV: Samsung QLED QE65Q7FNAT
              PSU: BN4400940A
              MB: BN94-12832K
              I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
              09-24-2024, 01:35 PM
