Samsung UE50MU6170 no image, no AVDD
  • badcapiggy
    • May 2021
    • Switzerland
    Hi All,
    Here we have a UHD TV with integrated TCON. The motherboard BN41-02568B failed, I could not get exactly the same but another BN41-02568B from a 6 series with a different sized screen.
    Backlight and sound are fine, but no voltages on the buffer board except 3V3 and no AVDD on the motherboard, either with or without the panel ribbon cables attached. The MOSFET feeding AVDD (Q400_UT, DMG4435SSS) is getting 12V at its Source terminal.
    AVDD is at high impedance to ground in off condition.
    I don't know where the other voltages for the buffer/panel are supposed to come from - MB or buffer board.
    Is there a link I need to check which tells the MB whether the panel has a separate TCON or not?
    Thank you!
    09-07-2024, 05:50 AM
  • shlomim412
    samsung ua55es6800 - no image
    by shlomim412
    hi
    having problem with samsung ua55es6800
    tv had backlight on, sound working - responds to the remote control but no image.
    check tcon board - had 12v in but no other voltages present.
    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
    when leaving only left side connected - again no voltages and no image.
    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
    kept trying to block less pins on the left ribbon cable...
    05-15-2024, 05:00 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
