samsung ue46es6100
  • pep2k21
    • Dec 2020
    • 35
    • Spain
    samsung ue46es6100
    this tv shows a big area (like 1/3) at the top of the screen darker than the rest, like a rectangle shadow but his shadow has sharp edges, is not like faulty leds darkness.
    i first think is fault from panel flex but i touch them and nothing happens.
    then i take out one of the tcon flex, half screen white and shadow is again.
    i take out the other tcon flex and i have low quality image but the shadow is gone so that makes me think that the panel is fine, and the tcon is bad.
    im i right?
    im ordering another tcon and will update
    • 12276
    • U.S.
    Re: samsung ue46es6100
    Can you post a picture of the faulty display?
    • pep2k21
      • Dec 2020
      • 35
      • Spain
      sure!
      the tv in these pictures its upside down. the dark area is at the top
        • 12276
        • U.S.
        Does it have same issue with just an over the air antenna hooked up, with no cable box or hdmi hooked up?
        • neilc6
          • Nov 2015
          • 1550
          Power up the TV with one side connected at a time between the tcon and panel. It does look like there are bad drivers on the darker side. If one side is good, you can try the tape cutoff method or ripping off the side tabs on the bad side if it has them. https://techhometravel.com/repair-of...lines-on-a-tv/
          • pep2k21
            • Dec 2020
            • 35
            • Spain
            if no source is connected screen is very dark. and i only have hdmi to test. i dont have aerial antena
              • 12276
              • U.S.
              Did you try a different hdmi cable or hdmi input on tv like hdmi 2 or 3 if available?
                • 12276
                • U.S.
                Or maybe try a device with rca plugs, like an old game system or dvd player etc.
                • pep2k21
                  • Dec 2020
                  • 35
                  • Spain
                  thanks a lot! it seems to work. i did as you say and now i get general low quality image but dark area is gone so i think i have to play with the size of the tape.
                  anyway i have seen this tcon board very cheap probably will change it i think. apart from this shadow area i would say there is something more wrong. later will upload pictures
                  • pep2k21
                    • Dec 2020
                    • 35
                    • Spain
                    will test in a couple hours good idea thank you
                    • neilc6
                      • Nov 2015
                      • 1550
                      Its not the tcon. The problem is in the panel.
                      • pep2k21
                        • Dec 2020
                        • 35
                        • Spain
                        really?
                        sure?
                        but doing the tape fix the line goes away, the problem is that i get very poor image quality
                        i testet hdmi, antena, and euroconector. all sources same problem
                        i have not ordered the board yet should not do it?
                        i upload pictures from first fix try. the tape i have is not very good for this i dont know if keep on trying with another tape. the panel has no line anymore, 🤣🤔 but the screen does not show properly
                        having a closer look to the fix post i think ill try to find the bad pin one by one and see what happens
                        • neilc6
                          • Nov 2015
                          • 1550
                          If one side of the TV shows a good image with the half screen test, this confirms the tcon is good.
                          Check the images in this thread. https://www.badcaps.net/forum/showthread.php?t=49281
                          Examples of tcon failures in sony tcon training manual https://dokumen.tips/documents/sony-...ng-manual.html
                          Sorry just re-read you can't get a good picture on either side. Workaround won't work since you don't have one good side.
                          • pep2k21
                            • Dec 2020
                            • 35
                            • Spain
                            Check this thread. https://www.badcaps.net/forum/showthread.php?t=49281
                            thank you. ok. i dont have good image with only one flex from tcon.
                            testing again just realised that
                            when only one side is connected, then the hole half screen is dark.
                            thats why i did not saw the dark area. dark is everything...
                            then i put both flex back and the problem only shows at the top of the screen. the rest at the middle and bottom is perfect
                            ill have a look to your post that will take me a while🤣
                            • pep2k21
                              • Dec 2020
                              • 35
                              • Spain
                              some more pictures
                              • pep2k21
                                • Dec 2020
                                • 35
                                • Spain
                                does this pannel have side drivers? i only see the bottom ones
                                • pep2k21
                                  • Dec 2020
                                  • 35
                                  • Spain
                                  i have closed the tv.
                                  i only get good image with both flex but have the top shadow area
                                  then, the panel is bad so there is no more thing to do with it
                                  thanks for the help 😊
                                    • 12276
                                    • U.S.
                                    That's a tough one, could be a bad panel but I wouldn't rule out a bad tcon either, with tcons usually being inexpensive, might be worth a shot. Could also be a problem with a component on the panel driver board.
                                    • angelos
                                      • Dec 2012
                                      • 573
                                      • South Africa
                                      I agree
                                      • pep2k21
                                        • Dec 2020
                                        • 35
                                        • Spain
                                        Originally posted by angelos
                                        I agree
                                        yes me too... but tcon is very very cheap. i maybe try i mean is not money only time and not too much so maybe is worth. i can sell it if problem is in panel.
                                        will update as soon as i have it. about 2 weeks
                                        any bet?🤣🤣
                                          09-06-2024, 06:20 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Samsung Galaxy Book Flex NP930QCG Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP930QCG Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930QCG boardview and NP930QCG schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 12:40 AM
                                          09-06-2024, 11:40 PM
                                          Samsung Galaxy Book Flex NP930QCGI Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP930QCGI Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930QCGI boardview and NP930QCGI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 10:50 PM
