Samsung PN51D550 Five double blinks
  • Muggz
    • May 2020
    • 15
    I recently had trouble with a Dell monitor, and you guys really went above and beyond to help me, and I was able to fix it! Thank you!
    My TV broke a couple weeks ago, and I want to get it fixed for my wife.
    Model: Samsung PN51D550C1FXZA (I often find it online as just PN51D550 or split as PN51D550 C1FXZA).
    Specs: 51" 1080p Plasma 3D TV
    Symptoms: After plugging it in, it turns on then off then on then off, 4-5 times total, and then the power light does 5 double-blinks. No picture on the display.
    Troubleshooting so far:
    - I found another thread about this TV, but the picture links are broken.
    - I bought a replacement power supply board (model BN44-00444A) from TV Parts Today. I swapped out the board, but the symptoms did not change. It cost about $40-45 shipped. The last picture below is the old board I took out of the TV. Pic 3 is the new board.
    - I am a novice to microelectronics, but I do have a multimeter, a hot air soldering station, and a LED blacklight tester (although I've never used it yet). I fix phones and laptops, and this is my first time trying to fix a TV, although I've repaired 3-4 monitors before.
    Would anyone please be willing to help me? I will do my best to follow instructions if anyone can walk me through what to do or what to check.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung PN51D550 Five double blinks
    A good starting point is to give the voltages within the two red boxes.
    If you can give the :-
    1. Connector name
    2. Pin Number, Legend Name, Voltage
    etc for all the pins
    • Muggz
      • May 2020
      • 15
      Thank you for responding. What do you mean by "red boxes" please?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It would have helped you if I had remembered to include the picture. Ooops
        • Muggz
          • May 2020
          • 15
          Here is a close-up of that corner of the power board. I'm not sure it's the power board though, because replacing it resulted in the same symptoms as before? That said, I will absolutely perform any troubleshooting steps anyone gives me to the best of my ability.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Check the resistance from VA and VS to chassis and see if there's a short circuit. If there is try and idenrtify which board. They go off to Xmain and Ymain boards. Unlikely to be the power supply if changed.
            • Muggz
              • May 2020
              • 15
              I am very sorry to disappear for so long. Real life stuff hit me. I was able to successfully test all of the pins going from the power board to the X and Y boards (although I could not tell you which one is the X board and which one is the Y board). All of the voltages are correct on both ends of the connectors. Of course, as it turns on and off 4 to 5 times, I am only able to get the reading for a split second before the TV shuts back off.
              Can anybody PLEASE advise the next step to troubleshoot?
              • Muggz
                • May 2020
                • 15
                Okay, what I tested were the logic boards, not the X and Y boards.
                So, I followed this guy's video, and determined the X board is bad.
                Does anyone know where I can find the same X board?
                It looks like the part number is LJ41-09422A. The one in my TV is R1.3. I found this eBay listing but it was R1.2. I also found this vendor, but it doesn't specify what revision the PCB is.
                How critical is it that the replacement board is R1.3?
                • Muggz
                  • May 2020
                  • 15
                  Replacing the X board fixed it!
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Thanks for the follow up.
                      09-07-2024, 05:50 AM
                    • Nairolf
                      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                      by Nairolf
                      I have a Samsung DM32D display.
                      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                      Here’s what I have tried so far:
                      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                      From these tests, I suspect the problem might be on the mainboard. Could anyone...
                      08-24-2025, 03:47 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
