6V or 3V LED??
  • jason123
    • Oct 2015
    • 1083
    6V or 3V LED??
    So, I have always used 3V 1W 3535 LEDs for backlight replacement. I have both the small pad anode and small pad cathode type.
    Just opened up a Vizio that uses the same size LED, but measuring the good ones, seems they're 6V, by then I had already replaced all 8 bad LEDs with 3V. Is that a problem?
    Yes, If the logic board is looking at "hard coded" voltage differential, the backlight might not turn on.
    Yes, if the current is controlled using the "hard coded" / expected voltages assuming 6V drop, then it's a problem.
    But.. don't these TVs drive current based on measurement across known precision sense resistor?? So if it lights up, should be oK??
    Curious to get experts thoughts.
  • neilc6
    • Nov 2015
    • 1550
    Re: 6V or 3V LED??
    For models that have protection shutdown due to shorted LEDs, the voltage needs to be correct (LG, RCA, Insignia). Samsung designs dont have shutdown and you end up with most LEDs shorted and possibly power supply damage. Havent done enough Vizios but the one I did do had local dimming so each strip was independently controlled. The only other Vizio I replaced had the backlights turn blue.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Re: 6V or 3V LED??
      I'm not certain I have this right but here are my thoughts.
      If a led strip fitted with 6V leds have 3V leds inserted, then the voltage drop across the strip will be lower by 3V for every 3V led used on that strip.
      Assuming that the 3V led can take the led strip current, let's say 150 - 200mA then the only thing that happens is the led strip voltage will be lower by 3V x number of 3V leds fitted to the strip.
      The led driver IC generally has an over-voltage and under-voltage input so if the voltage across the led strip drops sufficiently it could turn the led driver off.
      • jason123
        • Oct 2015
        • 1083
        Re: 6V or 3V LED??
        Thank you.. agree with all
        • Pipolups
          Corsair K70 LUX RGB dying LEDs
          by Pipolups
          Hi there !
          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
          10-08-2024, 11:58 AM
          DELL Vostro 3535 Notebook 3000 Specification for Upgrade or Repair
          This specification for the DELL Vostro 3535 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3535 boardview and 3535 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3535 Notebook...
          09-07-2024, 06:40 AM
          09-07-2024, 06:38 AM
