Re: TOSHIBA 40L3453DB red-green blinking light
1Gb very fine if you have less will be more fine
the software didn't recognized it and read it at auto?
I have been using 16gb fat32 and two others which are 4gb fat32 sticks
I have a 1gb stick, will that be ok?Last edited by Fergal22; 02-21-2021, 05:14 PM.Leave a comment:
after you finish with U11, take this file and put it on the usb drive no larger than 2Gb FAT32 with the firmware i linked to you from mega download... rename it to mb90_en.bin .. insert the drive at tv. press ok on rc and plug it in wall.. 5 seconds enough... leave it as much it need time.Attached FilesLast edited by Diah; 02-21-2021, 04:43 PM.Leave a comment:
please dump U11 and upload it here... after you are sure have clean dump.. over write it by flashing diif file
how big the usb drive you are using and at which format ?Leave a comment:
Turn on without holding ok button on RC just get red/green blinking, no screen back light
Then if i try with a flash file on the usb and unplug connect usb press ok on RC, get no light, release ok button after 10 seconds and still get no light
Attached is pictures of the location of the U11 chip on the underside of the boardLast edited by Fergal22; 02-21-2021, 04:06 PM.Leave a comment:
then just flash diif file and power it on.. let see... it sound to me we have some issue related with NAND or BGA... but we can by try to be sure of the issue..
U11 can you show me where it located... as diif package include it ?Leave a comment:
My friend gave it to me as it just went like this when he turned it on one day
I tried all 4 files you posted and just turned tv on that's all and got the following results
Toshiba 40L3453DB U10 Dump_repaired
No lights no screen, nothing
FINLUX__MX25L1606E
flashing green light only, no screen back light
MX25L1606E_U10
Polaroid SPI
flashing green light only, no screen back light.Leave a comment:
did this TV had history.. or you was not the owner of it before it become defect !!
i just confused why after all these U10 Files you have different results with it..
my previous file of repair i dont think it will bring any to you because of the compare was only at empty data.. see photo..... so please try this 3 files.. just flash and test them on the tv .. let see what you have at each version of this bootloader. LED indicator.. and screen back light... if one brought solid red STB light, turn it on from RC or from side panel of the set.Last edited by Diah; 02-21-2021, 08:26 AM.Leave a comment:
i took yours dump file and compared it with diif file.. both are same version.. yours dump one had one pause boot section was corrupted, i did rewrite it with hex. try flashed it, and dont do any more than plug in wall and turn on.. let see what you will have.Attached FilesLeave a comment:
Morning Guys,
Thanks Diif for the files, i tried the U10 file but no joy I'm afraid
Here are my findings when trying different flash dumps
Toshiba 40L3453DB U10 Dump Mine, must be Faulty
No lights-no response from remote or side buttons
Toshiba 40L5435DG Dump Flashed
MB9x_Faz3_V362H_Core bin file
Flashing Green Light
unplug connect usb press and hold ok on RC, get a green solid light, release ok button after 10 seconds and light just stays solid green
turn off and back on just get red/green blinking light, black screen
40L3453DB bin file
Same as above
17MB95 full v3.6.6n bin file
Same as above
17MB95 full v2.2.4t bin file
Same as above
UPG02
Same as above
Toshiba_40L1333DG_U10_25L1606 bin file flashed
Toshiba 40L3433DG bin file flashed
I think one or 2 of these two i got a solid red light when unplugging connect usb press ok on RC plus black screen, if i turned off and on again with ok on RC i get red/green blinking light
Toshiba U10=25L1606E bin file flashed, the one Diif uploaded
unplug connect usb press ok on RC, get a no light, release ok button after 10 seconds and still get no light
turn off and on without holding ok button on RC just get red/green blinking light black screen
I also trying with pressing input button the the side, no idea if that's the button you are suppose to press as i jus got red/green blinking light when trying this on all the above
I don't know what else to try, i might but another main board but just concerned it might not fix itLast edited by Fergal22; 02-21-2021, 03:20 AM.Leave a comment:
I surprised myself a while back when I passed!
Here you go.Attached FilesLeave a comment:
leave it.. its really spam side... this why its blocked over here.... try your own to flash u10 again... maybe with the dump you get from the chips.. or other... now you how to flash..
also check friends round you if some one own usb hub... i never thought you have programmer and this tiny things you dont ownedLeave a comment:
cant find the answers on google eitherLeave a comment:
then you can use USB 2.0 Hub , you will have 4 slots LOL
BTW: what you need are on this web... need to register first
that link takes me nowhere as the first part is missingLeave a comment:
BTW: what you need are on this web... need to register firstLast edited by Diah; 02-19-2021, 09:16 AM.Leave a comment:
if you have i8 mini air mouse keyboards good candidate for such condition tooLeave a comment:
Thankyou for all your advice
PS i tried using buttons on side panel as wellLast edited by Fergal22; 02-19-2021, 08:49 AM.Leave a comment:
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...09-06-2024, 05:33 AM
- Loading...
