I have a Magnavox 51mp392h. I started out have a convergence issue where the red would not move. I replaced the convergence chips, and the 12 convergence resistors. I can now move the convergence points and everything works fine through the Svideo, composite, and standard component inputs. When using the HD input, the crosses on the convergence menu seem to be wavy on the verticle axis. Some of the verticle lines are "c" shaped, some are "s" shaped. this occurs even when all convergence points are lined up. I can move the points, but the picture is still out of line.
Magnavox 51mp392h
Re: Magnavox 51mp392h
Yikes.
Must be done in service menu to do convergence after IC replacement and save it while in SD (480 only), then switch video input transfer the saved settings to HD in 1080 and touch up.) Then save it.
I know these chassis. You have to transfer the saved settings from SD to HD.
Original remote is *required*.
Cheers, Wizard -
Ingore first post of mine, this is edited post as 10 minute limit timed out on me.
Yikes.
Must be done in service menu to do convergence after IC replacement and save it while in SD (480 only), jump back to intial service menu, then switch video input, go back into convergence menu and transfer the saved settings to HD in 1080 then go into convergence and touch up.) Then save it.
I think high count Multipoint is what you are needed to do. The low count multipoint is for coarse adjustment and is generally skipped.
VERY, IMPORTANT to WATCH OUT FOR COOLANT LEAK or brown coolant (common too especially in blue, green comes second, red is immume to this; question: is your yellow halo picture?). Lot of these philips chassis of this type got passed on they incur huge bill to fix for leak or changing coolant due to excessive time. Philips uses lens to push down on the C lens and in turn compress the big grey silicone washer seal ring using E-torx size 8 or 9 screws, totally insane. Rest of other makers uses aluminum plate so lens can be taken off without spilling any (either philips #2 or 1/4" hex screws).
Very poor design chassis especially CRT seal design and philips is too cheap to sell us assembled CRT assembly even without a lens is fine when I got first box containing crt years ago from philips, I eagerly opened up a box of arrived CRT part and frowned, naked CRT for price of a Samsung assembled CRT with coolant filled? Thanks very much, goes the profit because this got eaten up by larger labor. RCA and Samsung and others ships CRT assembly with coolant filled. Samsung is cheaper on this.
How much have you invested in this repair yet and is it your first owner of this unit, even freebie? Crucially, is it yellow halo? If it is more than 100, drop it and go new LCD. These chassis was made 10 years ago.
Cheers, WizardComment
Thanks, that worked. Looks great now. I have owned the set since I bought on clearance 7 years ago. This is the first repair to the unit, and i totaled to be $45. I was planning on changing the fluid, but after looking, there are no leaks, and the fluid appears clear.Comment
Awesome. These units is average, make sure heatsink grease is plenty on these STK and squeeze against heatsink to make sure as spring clamp doesn't have sufficient pressure to quickly squeeze out grease.
The best one I ever seen is RCA's and Pioneer, Toshiba, Hitachi units because their CRTs are not too close to the screen or too small lens or lens not precision made to *specific* focal length and screen size. (this is reason for blurry at edges that I see all the time with philips and Samsungs)
by tonybig10Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...-
Channel: Schematics and Boardviews
03-07-2025, 01:03 PM -
by dqtechprocessor ryzen 3 PRO 2300U
i notice this beeping start when i installed driver AMD IO Driver....but without install that driver, laptop touchpad cannot be use...after installed IO driver, touchpad can be use but beeping when move cursor...any solution for this?...08-30-2023, 12:00 AM -
by 2elwHey,
Does anyone have a schematic or boardview for the HP Elite x2 G4? Motherboard shows "EMP20 LA-G931P". I've gotten 200 of these from my employer to unlock and its been hell since the EC rom is on the back of the board, im trying to find test points or any way to communicate to the EC or its rom without having to dissasemble the whole thing just to get to the back.
Thanks.-
07-03-2025, 02:33 PM -
by barrybahrHello,
The unit is stuck in an intermittent on/off cycle. When I plug in the power cord, the green "On" light activates without any command, flashes for a few seconds, then turns off. The red standby light comes on for a few seconds before the cycle repeats. During this time, I cannot turn off the unit manually; it will shut off automatically after about five minutes, and there is no picture. Occasionally, with repeated attempts to power it on, I eventually get a picture and sound, which function properly. When it does work, I measure several voltages, and they appear to be normal.... -
by pabloroggeriHello guys. I need a replacement for UTC1316 or KA2214, in my country I can't get either of them, it is for an inexpensive radio recorder, there is no point in searching for it on e-bay or Amazon. Thank you
- Loading...
