Samsung UE19ES4000wxzt turns off and turns on
  • Luis8
    • Oct 2020
    • 17
    • World
    Hi, i am not an expert with electronics so please have patience.
    I got this tv from my mother in lawm, it worked just fine until yesterday when suddenly it started to shut off and on continuosly.
    I measured voltages on the primary and the secondary and they all seems ok. When the TV reboots the 5V going out from PSU to the maiboard drop until the reboot is completed.
    Another things that i noticed is that when the TV reboots the processor on the mainboard is a little bit hot.
    Being that i have the same PSU of this thread and similar defect i resoldered all the pins listed in that image but unfortunately it did't changed the behavior.
    Sometimes the TV runs correctly and remain on and stable for hours. I was able to have it running for two hours straights with no faults, then i turned it off trough the remote control and leave it for 30 minutes... When turned on it started with the bootloop again.
    At this point i can't understand if the fail is in the PSU or the mainboard.
    Do you have any idea?
  • nomoresonys
    • 12331
    • U.S.
    Re: Samsung UE19ES4000wxzt turns off and turns on
    Your answer may be there in his first post of the link you give, try the eeprom reset if you didn't already, see what happens.
    • Luis8
      • Oct 2020
      • 17
      • World
      You are right, tomorrow i will try the eeprom reset and update the thread with results. Thanks for the moment
      • Luis8
        • Oct 2020
        • 17
        • World
        I tried the eeprom reset both connecting GND+SDA and VCC+SDA but no luck.
        I was also able (one time today once the TV it's been on) to enter factory menu and performed the factory reset but the fault remain.
        Can someone suggest how to proceed or what's worth to check/try?
        Thanks guys!
        • nomoresonys
          • 12331
          • U.S.
          Try unplug tv from power, unhook cable from powerboard to mainboard, leave unhooked, plug power cord back into powerboard, what is the result? does the backlight come on? recheck those voltages, is the standby voltage steady now? what voltage do you get on the rest of the pins?
          • Diah
            • Feb 2013
            • 6614
            Yours Mother in law love you so much.... do Resoldering all joints on power boards if it fix then good, if not take it back to in law and install it at her kitchen to keep the set always warm. :-)
            • Luis8
              • Oct 2020
              • 17
              • World
              You are right, i forgot to mention that in the first post. Yes if i disconnect the mainboard from the PSU the backlight turn on without issues.
              These are the voltages that i measured without the mainboard connected:
              pin 1 B13v 12.79v
              pin 2 EPWM 3.31v
              pin 3 B13v 12.79v
              pin 4 N.C. /
              pin 5 Vamp 12.79v
              pin 6 B_ON 4.66v
              pin 7 Vamp 12.79v
              pin 8 GND
              pin 9 GND
              pin 10 GND
              pin 11 B5V 5.25v
              pin 12 A5V 5.25v
              pin 13 B5V 5.25v
              pin 14 P_ON 3.10v
              I was able to have it on after a while today (after a thousand of prays ) and i measured the voltages while the TV was on, they are the following:
              pin 1 B13v 13.20v
              pin 2 EPWM 0.63v
              pin 3 B13v 13.20v
              pin 4 N.C. /
              pin 5 Vamp 13.20v
              pin 6 B_ON 5.14v
              pin 7 Vamp 13.20v
              pin 8 GND
              pin 9 GND
              pin 10 GND
              pin 11 B5V 5.21v
              pin 12 A5V 5.24v
              pin 13 B5V 5.21v
              pin 14 P_ON 3.33v
              I also desoldered two capacitors used to stabilize the 5V (10v 1000uF) and measured with an ESR meter:
              1. 1 - Capacity: 1024 uF (ESR 0,19)
              2. 2 - Capacity: 984 uF (ESR 0,23)
              They seems OK to me.
              What do you think about it? Any other idea?
              LOL this was funny Sincerely i want to try my best to repair it.
              I will check again the joints and perform a full resoldering if no other ideas come here
              Thanks a lot for your help and time guys!
              • nomoresonys
                • 12331
                • U.S.
                Seems like the issue is with the mainboard, maybe one of the voltage regulators? Suppose it could be a bad solder as mentioned or maybe a weak capacitor.
                • Luis8
                  • Oct 2020
                  • 17
                  • World
                  I will check capacitors and voltage regulators of the main. At this point i will also perform resoldering of all the joints in the power supply board.
                  Just to know, in case of a faulty voltage regulator it is possibile a behavior like that that sometimes works for hours? From what i know voltage regulator functions shouldn't be affected by temperature variation...
                  Thanks, i will try these paths and let you know!
                  • nomoresonys
                    • 12331
                    • U.S.
                    They can get faulty and be intermittent, easy enough to test for proper voltage tho.
                      09-07-2024, 05:50 AM
                    • Egidio85
                      Samsung UE55F8000SZ Turns on and off immediately
                      by Egidio85
                      good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                      This defect happens continuously, hearing the classic click of the relay every time.
                      Power supply board BN44-00636B
                      disconnecting the mains and lamps from the power board always causes the same problem.
                      Is it normal that without anything connected this power supply turns on and off cyclically?
                      any suggestions on what to check?
                      thanks in advance
                      03-11-2025, 12:45 PM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
