Hitachi Power LED flashing
  • samtron786
    • Aug 2016
    • 170
    • germany
    Re: Hitachi Power LED flashing
    Hello
    MP3398A protection pin find, unfortunately google doesn't tell me much about this MP3398A chip
    many thanks
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      The data sheet says operating voltage between 5 to 28 volts, VCC pin = 6 volts, Enable pin =>1.8 volts
      What voltages do you have?
      • samtron786
        • Aug 2016
        • 170
        • germany
        I can't measure that, I have to turn the power supply, but how? :-)
        I have no problems with LED all are fine
        I have two
        Power supplies bought the same problem
        Find MP3398A protection pin
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          If the leds are fine then what is the problem?
          • samtron786
            • Aug 2016
            • 170
            • germany
            hello i have found something in google with power supply not the place, can you please mark the place for me?
            ISET two resistors 5.09 K ohm and 4.68 K ohm
            Try the 6th leg (ISET) to increase resistance. Instead of 7 kOhm, use 12 kOhm, the current drops and the voltage protection no longer works.
            • kasfamily
              • Aug 2014
              • 774
              • Russia
              #26
              Remove the resistor 4701 from the red circle and solder it instead for example resistor 103
              • samtron786
                • Aug 2016
                • 170
                • germany
                #27
                many thanks
                • samtron786
                  • Aug 2016
                  • 170
                  • germany
                  #28
                  Unfortunately that didn't help me
                  • samtron786
                    • Aug 2016
                    • 170
                    • germany
                    #29
                    I tested the LED again, they are all fine
                    • bosmarin
                      • Mar 2017
                      • bosnia
                      #30
                      47 mF 160v
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • STKR123
                        Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                        by STKR123
                        As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                        I wonder if re-flashing the BIOS might be of any use here.
                        As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                        There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                        11-03-2024, 06:58 AM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
