Samsung UN65NU7300F bad T-Con?
  • msibytes
    • Dec 2020
    • 3
    I replaced the right side LED strip on this Samsung UN65NU7300F. It went well but I had to disassemble the TV again to adjust and really glue down the strip. Long story short, I ended up snagging one of the display buffer boards while walking past the LCD panel(I didn't use enough masking tape and it got loose).
    Now about 6 traces on the display buffer board are not connecting to the ribbon. I can't seem to get the ribbon traces to connect to the board traces when pressed together this doesn't affect the screen. Could trying to fix this issue have damaged the T-Con board?
    The left side has excessive brightness and reducing the backlight setting has no effect on it.
    The TV has 216 T-con PMIC fault counts, does it need to be changed at this point?
    Any help or advice would be welcome, thanks
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: Samsung UN65NU7300F bad T-Con?
    You need to try to fix those traces or I'd part out tv. how about a close up of the busted traces.
    • msibytes
      • Dec 2020
      • 3
      No busted traces, just the part of the ribbon that's circled in the photo has detached from the buffer board.
      • ajshoe
        ajshoe
        • Dec 2012
        • 477
        • usa
        tab bonding - tv is parts
        • abduln21
          • Nov 2020
          • 3
          there are some techniques to maybe repair it. Heat can sometimes be your best friend or your worst enemy.
            09-07-2024, 05:50 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
            09-06-2024, 11:40 PM
