Samsung UN75F6300AF
  • Hornnumb2
    • Feb 2011
    • 210
    Samsung UN75F6300AF
    Latest curb find, Samsung UN75F6300AF, brightest at the top and getting dimmer as you go down. It has a line across the top but it's not straight across. What should be my first check, Led string voltage?
  • Storyteller12
    • Jun 2020
    • 624
    Re: Samsung UN75F6300AF
    Yes,
    Test led voltages, but make sure it's like that on every source first. Also check and see if it's like that with the tv menu open. If so then most likely the led's. But until all voltages are checked can't say 100%
    • Hornnumb2
      • Feb 2011
      • 210
      Ok tested the 4 caps on board for backlight and get around 350v on 2 then 188 and 216 on the other 2. So am I better off replacing all strips or just some leds. The only thing that worries me is the line across the top that veers down at edge. What are y'all's thoughts? Thanks Michael
      • jjanssen7
        • Nov 2012
        • 252
        I'm working on one of these right now. A number of the strips needed to be replaced and the replacements, though used, are brighter than the ones left. So I'm thinking it's better to get a whole new set.
        • Hornnumb2
          • Feb 2011
          • 210
          Any thought on the line?
          • jjanssen7
            • Nov 2012
            • 252
            I can't see the line... closeup maybe?
            • Hornnumb2
              • Feb 2011
              • 210
              the second picture the top 1/4 of the screen is like divided a lighter grey color and on the left side it takes a juke down.
              • jjanssen7
                • Nov 2012
                • 252
                That just looks like the OSD from whatever you are using to generate the image. Go to settings/support/picture test and run that. See if it shows up that way?
                • Hornnumb2
                  • Feb 2011
                  • 210
                  Is there any suggestions to get the screen off without breaking it. I have it off by laying a board on top and flipping it but don’t know if that’s gonna work to put it back. Thanks
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    harbor freight suction cups - 4 of them or some helpers. Beer party ?
                    • Hornnumb2
                      • Feb 2011
                      • 210
                      Well after putting it back together, I have 3 vertical lines in the display. Could it be t-con ribbon cable not seated properly? Also one of the new strips of backlights does not work, I tested them with led tester before reassembly and one took several times to come up it would just lightly flicker. Dang I knew I should of had them replace it.....
                      • jjanssen7
                        • Nov 2012
                        • 252
                        In my experience those lines are from the ribbons to the panel being stressed when removing and installing. Sometimes with these older tvs they are easily tweaked. Where did you source the LEDS? If it's shopjimmy they will certainly give that kind of support.
                        • Hornnumb2
                          • Feb 2011
                          • 210
                          Yeah shop jimmy, just sucks I got to take it apart again.
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
