Toshiba 46PX200ZE led tv screen is dark
  • spdy
    • May 2018
    • 26
    • india
    I have toshiba 46PX200ZE led tv which has a 64 led side backlight array.
    The picture went black and I took out this side led array I found one of the leds
    has gone bad as it would come on for a couple of seconds only. I photographed and discovered the bad led and tried to replace it with a 6.1 volt zener.
    I was not able to make it work.
    I was able to light the leds by applying about 3 volts on them. Now I cannot do so, even though they pass the diode continuity test on the multimeter.
    Do leds show this even if they do not light up?
    What can I do to repair this array? Has the circuit before it (inverter?) gone bad? By the way the connector to this has 5 pins so assume there are four 16 sets of leds.
    Is a circuit diagram of this available?
    Thanks.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
    09-06-2024, 05:27 AM
  • sigmeyer
    Toshiba 50UL4B63DG faulty screen?
    by sigmeyer
    I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
    08-30-2025, 08:13 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
    09-06-2024, 05:59 AM
