Samsung LE32A552P3R / SMPS BN44-00213A Fuse keeps going
  • trunks81
    • May 2020
    • 265
    • Nederland
    Hello
    Got this board and in the begin the next parts where defective
    CM810 = 1KV 2.2nf
    QM801
    QM802
    NT811S = DSC_5D15
    And the fuse was blown
    After replacing these parts the tv worked for like 15 seconds and i had an image, After this the fuse did blow again.
    i did replace those parts again and now only the fuse in the fuse closet goes.
    Fuse on the board is good.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung LE32A552P3R / SMPS BN44-00213A Fuse keeps going
    Perhaps this will help.
    • R_J
      • 9558
      Check that the gate components are all ok,RM811, RM813, DM803, Dm804, DZM803 etc. you will likely need to remove one end of the component because of the parallel resistor
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Also check BD801S. If only the fuse is blowing then you may well have a damaged bridge rectifier.
        • trunks81
          • May 2020
          • 265
          • Nederland
          Look like the bridge rectifier is defective also,
          Iam getting very low ohm between AC (Also when desoldered)
          The type is TS4B05G, Can i please any rectifier back ?
          • trunks81
            • May 2020
            • 265
            • Nederland
            i replaced TS4B05G and now the tv is working
              09-07-2024, 05:50 AM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
