Screen replacement samsung 32
  • gbaicu51
    • Feb 2015
    • 29
    Hi guys . I have my led tv samsung ue32f5000ak and sometimes restart itself. I check capacitor and they are ok . My question : i ve seen on facebook an smart ue32h5500ak with broken screen for sale. Maybe anyone knows if the screens are tye same in those 2 models? Will be possible to have one good tv from 2?
  • Diah
    • Feb 2013
    • 6437
    Re: Screen replacement samsung 32
    simple answer yes.. they will share same boards and back light.. firmware could be different because the 5500 have internet and smart hub
    • trunks81
      • May 2020
      • 265
      • Nederland
      do you know which partnumbers are used in both tv ?
      • gbaicu51
        • Feb 2015
        • 29
        Thanks guys. Just losted the advert from fb pfff cannot find anymore. Anyway if i find again a smart Ue32 series can i use the boards on my Led screen?
        • Diah
          • Feb 2013
          • 6437
          yes.. the 32h5500ak all boards and the cover too useful because it had hole for the LAN cable
          • gbaicu51
            • Feb 2015
            • 29
            Just found another one: smart Ue 32M5520ak broken screen. could be compatible with ue32f5000ak ? Thanks @Diah for advice with cover
            • Diah
              • Feb 2013
              • 6437
              5500 /5520 all from same series h5 .. yours 5000 are flat ( simple with out extra) 5500 with smart WIFI LAN Bluetooth, i think the 5520 they add Dolby Digital beside DTS to the sound
              any way all better than yours LOL with h series and internet connection you can root it and install OSCAM to watch pay tv channel
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • ScHAmPi
                Samsung UE48JU7000 screen issue after backlight replacement
                by ScHAmPi
                Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                07-15-2024, 05:41 AM
              • FreakyMex
                Trouble to identify part (Lunii screen) for replacement
                by FreakyMex
                Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                02-17-2025, 01:16 AM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
