Hi everyone, I am new here so please forgive me if I have not formatted this correctly
I had a samsung TV where by it keeps clicking on/off but there is image when it does so. I opened it up to check for bad caps but they all visually appear fine. So I found this thread related to checking the mosfets:
https://www.badcaps.net/forum/showthread.php?t=22919
While checking to see if the gates were letting voltage through I noticed that if I put my volt meter from ground to the middle pin of either of the mosfets in the image indicated, the TV operates fine.
As such, I pulled the mosfets out thinking they would need replacement, but they seem to test fine (charge/shorting the gate enabled/disables throughput for the drain.
I also noted that unlike in the thread above, I still have the same issue if I entirely remove my mosfets.
Any assistance making sense of what is going on here would be greatly appreciated!
