Sony Bravia KDL-46EX700 vertical stripes and distortion repaired
  • Arti2020
    • Jul 2020
    • Finland
    This particular TV came with green color distortion on the screen and subsequent vertical stripes. The fault turned out to be in both mainboard and T-con board. There were damaged chokes/inductors in the mainboard next to the lvds connector as well was damaged solder joints under large chips on the T-con board (fixed by reflowing).
    Here's my clumsy video of the repair, maybe somebody would find it useful.
    https://www.youtube.com/watch?v=-QBv4rbZCzU
    Regards...
  • Petros_Z
    Led stripes for Toshiba TV 32W1433DG
    by Petros_Z
    Hello, I have the TV of the title and it has problem with the led stripes. The code of the stripes is VES315WNDA-01. Also on the chassis there is a code "Model VES315WNDS-01". Searching for spare parts I found that there are led stripes for each of those codes. I don't know if someone had changed them before. Based on what code should I order the spare parts? From led stripes or chassis?
    Thanks in advance and sorry for my bad English.
    04-02-2024, 02:59 AM
  • kotel studios
    Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
    by kotel studios
    Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
    In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
    08-06-2025, 02:07 AM
  • halen
    Hisense H55U7B vertical stripes
    by halen
    I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
    1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
    2. Connected only left side of LCD to tcon, big stripes
    3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
    Where could be problem?
    Tcon RSAG7.820.7932/ROH
    Main board RSAG7.820.8698/ROH
    Jan
    06-18-2025, 03:58 AM
  • korsar86
    Sharp LC-65CUG8052E stripes on the display
    by korsar86
    Hey, everybody.I'm asking for your help. Brought this TV in to replace the backlight. After replacing the backlight there are such stripes (see photo).
    The glass is not broken, decoders are intact, everything was done very carefully and in antistatic gloves. The experience of disassembling such diagonals is great. I do not understand what is the reason for such stripes that appear a couple seconds after turning on.
    Loops rewired, wiped them with alcohol, the connectors are clean. Who by experience can tell me why this happened? Perhaps at the reception did not notice when shining the...
    04-23-2024, 12:29 AM
  • ahoonid
    MacBook A1990 vertical stripes on external screen
    by ahoonid
    Hey everyone,
    I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
    The board is neat. Not opened before for sure. Just a little dust, nothing more.
    Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
    06-20-2025, 08:54 AM
