Re: Samsung UE46D6500 doesn't turn on and clicks
The problem is much common and is due to software conflicts. I ask to "shaking hand" which is the technical meaning of your guide? Can you explain? I see no sense in it.. For the fluctuating voltages i see that your tester has a BL icon that probably say its battery is low, so retest..
I changed the LED strips on mine and now it works.
I guess voxahbc gave up on this one? Is this problem fixable? I'm about to give up on mine.
I've got a similar issue with similar readings on a UN46D6420. I'll be following this thread closely. Good luck.
I would still lift a leg on that diode and retest, just to be sure.
Originally posted by kacper69 View Post"When push to button to turn on "Smart TV" logo shows up and turns off with an endless cycle."
I suppose the NAND memory has a problem.
1. You can "freeze" this chip ( IC1301) on 10 sec.
2. switch ON TV in service mode (INFO - MENU - MUTE - POWER )
3. do FACTORY RESET in service mode.
Sometime you need this operation 2-3 times.
And TV could be work OK.
In this way i rescue some Samsung TV.
Damn dude that waving hand is irritating.
This operation is without any update.
But TV set is like new, need setting everything in operator mode.
Any update voxahbc?
Inspect powerboard for any cold/cracked/loose solder joints, look closely at components on heatsinks and transformer joints as they take the most abuse, could be a bad capacitor??
OK,I re-read your post #4 again and see that you did report the Voltages on the power supply connector without anything connected to it except the AC input to the board.
Post #4:
1 OD_LEVEL 5.3V Max - fluctuating
3 OD_ON/OFF 5V Max - fluctuating
5 GND Continuity checked - OK
7 B13V 12.8V - fluctuating
9 B13V 12.8V- fluctuating
11 Vamp 12.5V - fluctuating
13 Vamp 12.9 V - fluctuating
15 GND Continuity checked - OK
17 B5V 5.4V - fluctuating
19 B5V 5.4V - fluctuating
2 P_DIM4 0V
4 P_DIM3 0V
6 P_DIM2 0V
8 P_DIM1 0V
10 B13V 12.8V- fluctuating
12 BLU 4.8V - fluctuating
14 GND Continuity checked - OK
16 GND Continuity checked - OK
18 A5V 5.4V - constant
20 POWER 3.4V - constant
So the standby is steady, the PS-ON is steady but other switched supplied are fluctuating. The strange part is that the BL-ON is fluctuating too which does not make sense because the pull-up resistor between BL-ON pin is connected to the standby power supply output which is steady.
Well I don't know what's wrong but I'll be watching this thread, hope someone can solve it.
Originally posted by budm View PostThe diode D9601 tested bad in the circuit because it is connected in parallel with LOW Ohms resistor R960, you can look at the bottom side of the board to see how the Diode and the resistor are connected together.
Samsung BN44-00427A
https://www.shopjimmy.com/samsung-bn...pply-unit.htm#
BTW, we never get to see what Voltages you have (you power up just the power supply board) on the power supply connector when the connector from the power supply NOT connected to the main board.
Originally posted by nomoresonys View PostDid you check the voltage regulators on mainboard, he's checking them in video in post #11.
Have seen lots of main board issues with the D series. Try freezing the NAND with upside can of duster and see if it turns on.
Originally posted by voxahbc View PostI just did. I got a bad diode shorted. It blinks red on the multimeter either way. The others passed the diode test.
Samsung BN44-00427A
BTW, we never get to see what Voltages you have (you power up just the power supply board) on the power supply connector when the connector from the power supply NOT connected to the main board.Last edited by budm; 04-09-2020, 04:30 PM.
Ok, easy way to verify is just clip a leg in the middle so it will be easy to re-solder if it's ok and retest out of circuit.Last edited by nomoresonys; 04-09-2020, 02:44 PM.
Originally posted by nomoresonys View PostWell did you check al the diodes per post #10??Last edited by voxahbc; 04-09-2020, 02:25 PM.
