Samsung UA32H5100AK 32" FHD TV panel or tcon fault?
  • Ghost729
    • Mar 2020
    • South Africa
    Hi guys. Sorry if this issue has been addressed in a previous thread.
    Two weeks ago, my TV (which I use as a 2nd monitor for my PC) started displaying some weird lines.
    Basically it's black horizontal lines that makes it look interlaced and some green lines. Check the pics for more info. It seems to also be related to temperature, because if the TV has been off for a while and I switch it on, there's no problem, but eventually it goes bad. Regardless of input and even on the OSD it shows up.
    I did some research to see if I could diagnose it and thought it could be the tcon board, but a seller of tcon boards on Ebay mentioned in the description of a tcon board that horizontal lines are almost never caused by the tcon board. Now I am not sure if it is the panel or tcon.
    Considering the price of a 27" monitor, I don't want to spend too much trying to repair it. So I am wondering if the community here can help diagnose the issue and give me some advise on whether it is worth repairing?
    TV Model: Samsung UA32H5100AK 32" FHD TV
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
  • Anonmis
    Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
    by Anonmis
    Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
    The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
    12-01-2023, 04:31 PM
    09-07-2024, 05:50 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
