LG 43UK6300 - Audio & Backlight, but no Video
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4515
    • Italy - Milan
    Re: LG 43UK6300 - Audio & Backlight, but no Video
    • whatusername
      • Dec 2013
      • 456
      Originally posted by Davi.p
      It's a different model but it still has th exact same issue apparently it's something something that happens to a lot of OL80T v's that has to take on board built into the main board but nobody has but nobody has a sure fire fixed for it
      I am on board number 4 and still have the same issue
      • tmaster21
        • Feb 2021
        • 28
        • Portugal
        Hello . I have one 43UN7100 here on repair shop right now,exacly same problem,same board...
        left ribon cable makes the VCC from panel went down to 0v soon as i connect it. lvds cable disconected and i have 17v ready on cap near lvds conector(lcd power pins).
        SO! the panel is pulling much current and the mainboard shut power off ,or is an feedback signal failling from panel to the board.
        I will not order any mainboard because i belive the issue it's on panel.
        the transistor that you talk appears be ok. hight impedance,no burn marks ...
        Anyone knows how is the panel feedback working?
        • tmaster21
          • Feb 2021
          • 28
          • Portugal
          Before reassemble everything,to be sure ,i feed 15v @300ma on AVCC on testpin from panel and it really was in in shortcircuit when powered,because without power, on multimiter it was hight impedance. I think it's a problem on ic's that ate inbuild on flatcables that connect inside the lcd.
          • Breadwitholives
            • Aug 2022
            • 6
            HI Guys
            I have a similar problem.
            LEDs working correctly. Tried the trick taping certain pins on the flat cable to the screen worked correctly for a bit , but with the bottom of the screen with disturbances, but it is not working anymore. I ordered a new mainboard from ebay for 10 quid and see if that works.
            If i try to disconnect one of the two flat cables, the normal picture does not come back.
            Also, what are the two long narrow boards attached to the lcd screen?
            Any help will be much appreciated!
            Livio
            • carmine
              • Sep 2022
              • italy
              #26
              Originally posted by lcdrepair
              I just fixed one of these exact sets. The tcon is tab bonded to the lcd panel. I pulled one side from the mainboard . Turned on and same problem. Reconnected ribbon pulled other side and got half screen working perfect other half white. I used tape method. Scotch tape Covered 6 pins starting from pin1 on the ribbon that causes whole screen to blank. The whole screen came up looking fine. Is trial and error covering the right pins. Something is obviously failed and tape has bypassed issue for now lets see how long it lasts.
              i have an lg43uk6300mbl with the same problem.
              when i remove cable 1 or cable 2 i don't have half screen but the same blue screen.
              why?
              • samson7point1@yahoo.com
                Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                by samson7point1@yahoo.com
                The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                The player processes the audio signal using two different reference frequencies. The "R"...
                04-30-2024, 11:22 AM
              • SolarFlare
                Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                by SolarFlare
                My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                The TCON board has the following Chips -
                Samsung VTU63A0
                RT6939 - 2nos.
                and all these chips are getting real hot within a minute, I dont know if this is normal....
                06-26-2022, 08:58 AM
              • Max514
                Samsung UN55H8000 sound but no backlight no video
                by Max514
                Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                • Unplugging the main board cable at the power supply >>> backlights came on.
                • BLU_ON signal from the
                04-14-2022, 10:34 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
