Just a quick one, on this Laurus, if you go into the Picture menu to change settings, the Backlight adjust option is greyed out, I have had this before on other Vestel sets and cant remember what to do to 'ungrey it' so to speak
					Adjusting backlights Vestel - Laurus PH55CURVEUHD
			Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
 Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
 The TV was stuck on the logo and I couldn't access the update menu.
 I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
 The image result was good, but the image is inverted.
 The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
 Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
			by France_53Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
			by max789Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
 I made the following tests:
 1. Disconnected the main board from Power Board = backlight works.
 2. Connected the main board and disconnected the T-Con = backlights does not work.
 So I ordered a main board from Ebay also BN41-02156A but from...
			by bpcannan'Morning,
 I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
 Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
 I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
 I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
			by jesteraceHi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
 However, I am in a dilemma.
 I tested the backlight outputs with the lights disconnected...
- Loading...
