Sony KVM1621 16" crt TV
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4538
    • Italy - Milan
    Hi, my second post... i've opened a tv which i suspected in cold solderings,
    but i've done a stuoid thing when discharging the big cap, i put the discharger in the wrong place, in the scheme below i marked C and D the right point for the Cap and A - B the wrong place i done.
    <img src="http://web.tiscali.it/bps_impianti/schema%20Tv.GIF">
    After that tv brokes and i can only say which measurements i've
    done on the IC and the transistor and the correct values from
    schematic sheet:
    IC pins my measure scheme meas.
    1 -41,x -41,2
    2 222 0,3
    3 303 268
    4 9 0
    5 -33 -33
    the transis.
    B 0 0
    C 222 0,3
    E 0 0
    transistor and diodes are not short or open.. thankyou, bye...
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4538
    • Italy - Milan
    Re: Sony KVM1621 16" crt TV
    Sorry stupid not stuoid ...
    the link is http://web.tiscali.it/bps_impianti/schema%20Tv.GIF
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4538
      • Italy - Milan
      Sorry B in the transistor measures 9v..
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4538
        • Italy - Milan
        Sorry!! My new autorange tester makes me mistake, the outputs of the IC that i
        mentioned are all correct apart a little discrpance on pin3, 303v instead 268..
        there are no outputs on the secondary side of the big Transformer , there is
        300-320V on input part on two pins, the one coming from + of big filter capacitor,
        the other that coming from pin 3 of IC, the other three are millivolt..
        • Krankshaft
          • Jan 2007
          • 2328
          You're going to have to buy a service manual for this set which will specify the proper voltages then you can compare them to what you have.
          There is a handful of things you could have blown during discharge short of posting us a detailed schematic illustrating which cap you discharged and where you discharged it to see what paths the current might have taken and more importantly through what semiconductors. There isn't much we can do.
          Not to mention you haven't described what operating condition the set was in PRIOR to the blowout.
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:27 AM
            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
            09-06-2024, 05:30 AM
            Sony VAIO VPCEB4E0E/PI E Specification for Upgrade or Repair
            This specification for the Sony VAIO VPCEB4E0E/PI can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEB4E0E/PI boardview and VPCEB4E0E/PI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
