Re: Phillips LCD - Static on A/V source
good to hear you had proofed its source issue.
any HDMI upscale converters with out source power supply could do good jobs..
converters with out out source power are useless.
I think you’re right. Just found another source that uses av and picture is clear. Should have tried before but didn’t think it was a source issue.
Do you think those av to hdmi upscaler converters would clear it out?Leave a comment:
Just tried there are no settings from the source. It's a handheld nintendo emulator type with games. No settings to adjustLeave a comment:
But the same source on another tv looks clear. Could still be a source problem?from his first photo of the AV source the menu text look clear and the noise at JPEG back ground. its tell the problem at the source not the set. out put signal from the source need to change between YGBR to RGB. also the resolution of the signal... and all screw of boards chassis need to be in place too.Leave a comment:
I tried both Y and green in component and no image from either one. If I ohm test ground of av connector to ground of board and chasis it's 0 ohmsThat interference does look like the video signal ground is missing. When component video is selected, did you plug the video signal into the Y or green component input jack?
The video signals go from the a/v jack board to CN702, through the power supply board traces (no components) to CN302 which connects to the digital board, and goes through a 0Ω resistor and a .1µf cap and into the Zoran ic.Leave a comment:
If I pull out the video plug where the ground isn't connected the interference does change but still not clear. No video signal when I try on component input. Do you think it's related?Don't you have the service manual for this tv? It sure looks like the video ground is not making contact, If you pull out the video plug so the rca ground is not connecting does it change the interference? I can't see why you can't get a video signal on the component input. that would also check a different input that comes from the a/v boardLeave a comment:
Ah ok. Yes having all screws on and tight causes no difference. I’m about to just order an ab to hdmi converter for $10 and call it done I thinkLeave a comment:
Most tv's these days don't have a mains ground, That is not your problem, if it was, don't you think it would also effect the hdmi and rf input also.
Have you tried installing the power supply/inverter screws to see if that has any effect on the interference?
Any filtering in the a/c input circuit is to prevent noise coming OUT of the tv's switching power supply.Last edited by R_J; 12-19-2019, 08:23 PM.Leave a comment:
I noticed this tv’s mains plug doesn’t have a ground plug. Would that cause noise? Though I doubt it would be designed without a ground plug without filtering noise through the inputsLeave a comment:
Actually tried that before and get no picture at all. Not sure if it's the source I'm using or notLeave a comment:
Try the component input, You can switch the TV input to component and just plug the source video into the green input, that should give a green only picture. and see if the interference is still there.Leave a comment:
Visually checking all connections to the a/v board. Solder joints all look good too. I tried removing the ribbon cable and cleaning the contacts but that didn’t do anything.Leave a comment:
By A/V I will assume composite input or S-Video, So if hdni is ok, then the fault is not likely on the digital board (top right board). I would start by checking if you are missing a ground between the a/v board and the main/power supply board
If the problem is with the VIDEO input, check the trace for in the signal path, maybe there is a poor connection on one of the ribbon cables between the boards
If there is a poor ground for the video board, you will be picking up noise from the ccfl high voltage circuit which will interfere with the video signal.Last edited by R_J; 12-19-2019, 11:57 AM.Leave a comment:
by LvsitanoI am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
First... -
Hello I Need to Clear this Bios Password
LENOVO V15 IIL GS44D GS54D NM-C711
I Write another to password cleared But Hdd Not detected
So Pls Need to Clear this bios Password...-
Channel: BIOS Requests ONLY!
by LarrySaboTonight I broke the battery connector on the motherboard of this laptop and need to source a replacement. See pictures. The marking seems to read B6u. The sticker on the motherboard reads TCZRFN6X00230 P03AJD BA92-20746B 06 29. If someone could suggest a proper part number and source, I would be very grateful....
by Imdeksn99ASUS fx505gt rev 2.0a bios request clear ME
Need a bios laptop turn on but no display
its 8Mbits Files
bios is
W25Q80EW 1.8V 8M-BIT​
NEED HELP GUYS
OR PLEASE CLEAR ME for me thank YOU-
- Loading...
