Samsung UN78JU7500FXZA 8 blinking light code
    • 12323
    • U.S.
    Re: Samsung UN78JU7500FXZA 8 blinking light code
    This is a really good video, he explains things very well: https://www.youtube.com/watch?v=ocqnqmBxiqY
    • baleman2
      • Nov 2019
      • 20
      This legend is for CM803 - correct?
      I'll still be following your instructions in one of your initial posts? That is, test before plugging in power; then, test again after plugging in power?
        • 12323
        • U.S.
        Yes that's it, now watch video in post #21.
          • 12323
          • U.S.
          I always say if a picture is worth a thousands words...then a video is worth a thousand pictures.
          • baleman2
            • Nov 2019
            • 20
            This should be it.
            Am I still following your instructions from a previous post, i.e., test before plugging in the power; then, test after plugging in the power?
              • 12323
              • U.S.
              #26
              Ok, first try this simple test, with power cord unplugged, unhook cable from powerboard to mainboard, leave cable unhooked, now plug power cord into powerboard, see if backlights come on and stay on. The powerboard is the one we have been looking at, the mainboard is the one with the video connections like hdmi and rca jacks etc.
                • 12323
                • U.S.
                #27
                You did watch the video?
                  • 12323
                  • U.S.
                  #28
                  Do the simple test in post #26, see what happens then do this, just as instructed: Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on. So we can see all the voltages and what they are doing. Try to do test just as instructed.
                  • baleman2
                    • Nov 2019
                    • 20
                    Watched the video. Will do all this tomorrow and report
                    • baleman2
                      • Nov 2019
                      • 20
                      Let me refer to post #26 first.
                      Problem 1) Not sure if it's my particular Samsung model or not, but I do not see a backlight anywhere on the back of the TV. Have looked at other videos and most show an orange? light that gets referred to; however, I see no such light on this back panel.
                      Problem 2) In reference to the legend I posted showing voltage settings for CNM803, it looks as though ANY voltage reading I receive on my tester should be 13v. I see no other voltage readings on the legend. Is this correct?
                      • baleman2
                        • Nov 2019
                        • 20
                        In trying to get readings from my Klein meter, I've been having trouble getting valid readings by inserting my "red" lead into the connector as shown in several different videos.
                        I have unplugged the connector (shown in the picture) from the Main Board - the board that has the RCA, HDMI, etc. connections. The other end remains connected to the Power Board; so, I'm assuming that voltage readings are still valid. In this manner I'm able to touch my "red" lead to each of the silver squares as pointed to in the picture.
                        Being a novice, I don't know if the PIN #'s start on the left or the right of the picture, i.e., is PIN #1 on the left or the right?
                        However, the boxes do contain voltage readings associated with each pin.
                        Second picture contains voltages of the silver tabs after flipping this connector over.
                          • 12323
                          • U.S.
                          #32
                          Your backlights are inside your tv, when they are working the screen should light up and you can see the lights glowing thru the little holes on the back metal panel. Another video there for simple troubleshooting: https://www.youtube.com/watch?v=fSCf1xxLjNA
                            • 12323
                            • U.S.
                            #33
                            For the voltage test of CNM803, you will with all the boards hooked up test, leave the connector in place, report all 22 voltages, you need to type the name and number of the pin and expected voltage if it's marked, test with the tv plugged in but not powered on , which is standby, write that number down, then just hit power and also write that number down, among other things, we want to see if there's voltage on pins 16 and 18 and if they change when you power up the tv.
                              • 12323
                              • U.S.
                              #34
                              See how he's testing the connector in the video in post #21, you will do it just like that.
                              • baleman2
                                • Nov 2019
                                • 20
                                Have watched the video several times. Video shows connector with just 1 row of wires on the connector with relative ease of knowing which Pin is Pin #1. Connector on my Samsung has 2 rows of wires. I don't know how to determine which row begins with Pin #1. If the numbers 21/22 at the bottom left of the picture are telling me that pins 21 and 22 are on the left hand side of the picture, is the top wire 21 and the bottom wire 22? Or, vice-versa?
                                  • 12323
                                  • U.S.
                                  #36
                                  Look by the connector, see the little 1 and 2, other end has 21 and 22.
                                  • baleman2
                                    • Nov 2019
                                    • 20
                                    So, are all the odd numbers on top and even numbers on the bottom?
                                      • 12323
                                      • U.S.
                                      #38
                                      https://www.badcaps.net/forum/showthread.php?t=80730
                                      • baleman2
                                        • Nov 2019
                                        • 20
                                        $5,000.00 TV in 2015. Not going to trash it just yet. Power Board can be had for $64.95. I'd rather waste that much money troubleshooting than give up.
                                          • 12323
                                          • U.S.
                                          #40
                                          That's the spirit, don't be afraid, just do the testing.
                                          • matty24
                                            Samsung UE50MU6172 - red light blinking
                                            by matty24
                                            Hello. I have problem with Samsung UE50MU6172.
                                            TV won't turn on, red standby light is blinking.
                                            Power supply BN44-00807A is fine. I replaced it with the new one.​
                                            Main board BN41-02568B (BN94-12530E)
                                            I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                            03-02-2025, 08:57 AM
                                          • Fergal22
                                            Samsung UE40F5300AK blinking red light
                                            by Fergal22
                                            I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                            When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                            I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                            Any help would be appreciated...
                                            02-02-2023, 09:19 AM
                                          • norbiszoke
                                            Samsung 50AU7172, only blinking red light
                                            by norbiszoke
                                            We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                            Regards, Norbert!...
                                            04-17-2024, 06:54 AM
                                            09-07-2024, 05:50 AM
                                          • 3DDD
                                            Samsung UE46D6100 LED TV blinking red light indicator
                                            by 3DDD
                                            Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                                            02-20-2025, 12:51 PM
