Samsung UE32F5000AKXZT does not work anymore
  • Marco Sulla
    • Nov 2019
    • 5
    • Italia
    Suddenly, my TV does not work anymore. It powers on and the display become more bright, but the TV does not respond to any command, nor via remote control neither via manual control (the one behind the TV itself). To shut it down I have to remove the electrical wire
    What can be the problem in your opinion? Can I solve it in some way?
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Samsung UE32F5000AKXZT does not work anymore
    main board failed
    • Marco Sulla
      • Nov 2019
      • 5
      • Italia
      I opened the TV. The main board is apparently intact (apart the fact Samsung did not put two screws...). Probably it's a fuse?
      I know that exists a sort of "dryer" that can be passed at short distance all over a motherboard. In this way it liquefies the fuses. If the fuses are auto-restoring ones, when they solidify again they are restored.
      Do you think that in this case I can try to use such a system?
      • Marco Sulla
        • Nov 2019
        • 5
        • Italia
        Up... ô¿ô
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Just scrap it
          • Marco Sulla
            • Nov 2019
            • 5
            • Italia
            Emh, I know it costs very few bucks, but since I do not use TV very much, this is a good excuse to learn how to repair circuit boards.
            I do not remember what was the name of the "board dryer". Anyway I know there are methods to identify broken fuse and restore them. Do you have some suggestion?
            • KvnTM
              • May 2018
              • 434
              There is no such thing.
              Measure voltages from the PSU and make sure they are all correct to begin with.
                09-07-2024, 05:50 AM
              • vincentedel
                Samsung SyncMaster 740n Phase Control Issue
                by vincentedel
                I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                04-22-2025, 12:33 AM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
