Samsung UN65KU7000 Backlights
  • muscatintechguys
    • Aug 2016
    • 4
    Hello. I have a Samsung UN65KU7000 where the backlights were not working. If the TV was in a certain position, the left strip of back light would turn on but would be intermittent. I took the back off and wiggled on the cable that runs from the Power Supply board to the LED Strips. Now the left side of the TV seems to be working correctly with no cutting in or out, but the right LED Strip has not turned on at all.
    Any recommendations on checking power supply or other components before I try to take the panel off?
  • CapLeaker
    Leaking Member
    • 8178
    Re: Samsung UN65KU7000 Backlights
    check the voltages on each backlight string. Also some clear, straight shot quality pictures would help, so we can see something. Then we can go from there.
    • muscatintechguys
      • Aug 2016
      • 4
      So I got some voltages for cable running from the power supply to the LED lights -
      1. 216v
      2. 118.7v
      3. 216v
      4. 118.7v
      5. NC
      6. NC
      7. 118.6v
      8. 47.8v
      9. 118.6
      10. 47.8v
      11. I had to put red probe on ground - climbs to 200v and drops and goes back up
      12. Same as 11
      • R_J
        • 9548
        Looks like a problem in the panel
        pins 1&3 are common, pins 2,4,7 & 9 are common, 8 & 10 are common, 5,6,11 & 12 are not used.
        One string connects between 3 & 4, the other string connects between 7 & 8
        1&3 are the supply voltage, 8 &10 are the return.
        3&4 led string has about 100v across it, 7&8 has about 70v. I would geuess the fault is wihin the panel, maybe where the strips connect together.
        Do be very carefull if you remove the lcd panel.
        • muscatintechguys
          • Aug 2016
          • 4
          I'll be attempting to remove the panel tomorrow. I'lll let you know how it goes. Thank you for the reply!
            09-07-2024, 05:50 AM
          • max789
            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
            by max789
            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
            I made the following tests:
            1. Disconnected the main board from Power Board = backlight works.
            2. Connected the main board and disconnected the T-Con = backlights does not work.
            So I ordered a main board from Ebay also BN41-02156A but from...
            01-18-2024, 06:56 AM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
