LG 50PQ10R Plasma Powersupply
  • freeman3020
    • Jun 2019
    • 30
    • Palmo
    Hi all
    i have problem with power supply that not get 17V or va vs
    firstly my power supply not get any output power i can get 4.5 volt for Microcontroller on the secondary side of AUX unit , i don't know how this microcontroller work so i pulled-up some pins to switch main power relay and trigger mosfet gate to get output , i can get 4.5 on 5v pin and 12 volt output , and switched relay to supply main power circuit , ic L6599D work for less than second then switch off , no short on any diode or capacitor
    why microcontroller not switched circuit or relay , is it on protection mode
    any suggestion ??
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
  • jm1234
    9V relay temperature 40C
    by jm1234
    Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
    I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
    05-09-2024, 03:03 AM
  • edugimeno
    Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
    by edugimeno
    Hi everyone!
    I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
    I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
    This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
    To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
    I respected the polarity, positive to cathode of protecting diode
    So provided all...
    04-18-2024, 01:15 PM
  • jimbofz
    samsung plasma ps50 c580g1k slow tripping relay
    by jimbofz
    Hi ,this appears to have 2 faults
    black lines on raster and faulty main board ?
    let me explain futher
    at switch on the relay does a few slow clicks with red led blinking and repeats every 10 seconds .i ran the psu into 2x 100w lamps and it runs fine all day supplies good .
    i removed y sus and x sus checked for dry joints and checked all igbt anf fets all ok
    next i removed buffer and checked for any s/c buffer ics all ok
    so i unplugged feed to main board from logic board and linked test points pin 3 and 4 ,
    tv still trips but now i get plain...
    03-15-2021, 02:18 AM
    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    I was working on this CNC machine today found no keyboard functioning no control relay powering on
    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
    Found shorted diodes on main controller relays there are 3 of them that...
    01-07-2023, 05:43 PM
