UE40D5500 LAN problem
+ More Options
Posts
  • chrle
    • Sep 2013
    • 158
    • slovakia
    hello , cant connect to internet trought LAN connection
    I plug cable to tv but nothing show in Network Settings
    what I need to check?
    I solder pins on connector but still nothing.
  • chrle
    • Sep 2013
    • 158
    • slovakia
    Re: UE40D5500 LAN problem
    I connected wirelles usb stick for samsung tv but still not working
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • davg
      Home network connection problem
      by davg
      I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
      03-06-2021, 07:13 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Rofix
      Asus H110 M-K network card problem
      by Rofix
      Hello I wanted to kindly ask for advice or this Asus H110 M-k motherboard, which unfortunately does not detect the network card to connect to the internet, I checked some voltages on the REALTEK8111-CG chip, on pins 11, 23, 32 I found 3.3 V
      Thanks to everyone in advance for any advice​...
      11-22-2024, 05:24 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
