LG 42PQ1000 Plasma Failure
  • slash23
    • Oct 2011
    • 4
    Hi, My 42PQ1000 LG Plasma TV started doing this problem
    What could be?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42PQ1000 Plasma Failure
    Faulty Z-SUS Bd.
    • slash23
      • Oct 2011
      • 4
      Hi
      Are you sure? Cannot be T-con or Ysus?
      • PlasMatt
        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
        by PlasMatt
        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
        09-20-2025, 06:50 PM
      • alfredomfr1
        TV Plasma LG 60PN5000 ZSUS 15v missing
        by alfredomfr1
        All Voltages are OK except ZSUS 15v.
        YSUS board disconnected still 15v missing.
        ZSUS was replaced: 15v missing.
        Any help will be appreciated...
        04-29-2022, 11:26 AM
      • npielawski
        MacBook Pro late 2016 (820-00239) with multiple failure modes.
        by npielawski
        I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
        I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
        10-15-2025, 01:53 AM
      • akavintz
        LG 50PS8000 Plasma has started to flicker.
        by akavintz
        A few weeks back my plasma lg tv developed a flicker along with a red line across the very bottom if the screen.
        The line appears to of disappeared but the flickering persists.
        I have included links to a couple of videos.
        https://youtu.be/3fOnK9bcWN0
        https://youtu.be/kUEvuzDf9UE
        I studied electrical engineering at college and build pcs but this will be the first time i have opened a modern tv.
        Can anyone point in the direction of what i should be replacing based on the videos?
        Thanks...
        09-27-2021, 02:38 PM
      • puccovelli
        Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
        by puccovelli
        Hi all, I hope this is the right place to post.
        I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
        I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
        1] Could someone confirm what the component that has blow actually is (and where I could get another from).
        2] Whether this component is likely to cause the RAM failure issue, and if replacing...
        10-11-2025, 06:30 AM
