Samsung LN40A750R1F intermittently not powering on
    Referred from r/techsupport for my television issue. Below is a video of the problem as it is happening. Suspected capacitors, can anyone confirm? If so what is the replacement part number?
    https://youtu.be/XXdaBmW4H_4
    Re: Samsung LN40A750R1F intermittently not powering on
    Post some pictures of ALL THE BOARDS in your tv. Also one of the whole back of the tv.
      +1.
      You will need to do some Voltage measurement to help narrowing down the cause of the problem.
        As requested
        https://imgur.com/gallery/6q6do5t
          You have obvious bulged electrolytic capacitors on your power supply. Top right corner I see three tops bulging and not flat. I would replace all 7 capacitors in that area with Rubycon PX or ZLH series from Digikey.
          From a service bulletin for BN44-00197A - CM804, CM806 1000uF/25V and CM809, CM812 1000uF/10V. The others not in the bulletin but I would replace anyways. Confirm with the marking on the side of the capacitor. Note polarity when installing. The negative side is always marked.
            There are repair kits on ebay for under $13. Don't buy the super cheap one that uses CHONG capacitors.
              bought a power supply board from ebay and it's back in action. much obliged for the advice
