Originally posted by Demonata08
View Post
Element elefw605 power issue maybe?
Re: Element elefw605 power issue maybe?
Originally posted by R_J View PostIt could also be that if that 5 volt standby being only 3 volts, when you first plug in the tv, the eeprom and microprocessor only see 3 volts instead of 5 could cause it to be confused.
This low voltage could be a bad secondary cap or one of the small startup caps in the primary
Originally posted by budm View PostCanned air duster is only $3 ~ 4.
Unless it comes out cold in the can.
Originally posted by budm View PostYou usually cool it with freeze spray (or us canned air duster upside down) then plug the TV into ac outlet and try to turn it on.
Plot twist..the freeze sprays cost as much as a new eeprom lol
If i was to try heating it again. How hot would you guys go? Mine goes up to 500.Last edited by Demonata08; 05-18-2019, 11:17 PM.
It certainly could be the eeprom, I have had luck with freezing the eeprom ic. But you need to unplug the tv, then freeze the eeprom, plug in the tv and try turing it on. The eeprom is read at plugin, after its pluged in heating or freezing usually has no effect
Originally posted by budm View PostIt does sound like EEPROM problem.
Originally posted by R_J View PostThats better, When the tv is off what is the BL_ON voltage, sometimes it can be either a high or low to to turn them on
Thats better, Ok so it is the whole tv that won't turn on. Can you post a clear picture of the back of the power supply board, If that standby voltage is only 3 volts and it should be 5 volts that would cause the problem.Last edited by R_J; 05-18-2019, 10:45 PM.
Originally posted by R_J View PostSo what is the problem with the tv? is it just that the backlights don't always come on or is it the complete tv does not always come on?
And the TV shows no signs of life when you try to turn it on. It has a red standby light that doesn't blink or change when you hit the on buttonLast edited by Demonata08; 05-18-2019, 10:40 PM.
Originally posted by R_J View PostOh that's a megmeet power supply, not the BA3AU0F0102 3
I see your 5VSB is only 3 volts, that should be 5 volts I believe but could be wrong
Also can you attach the pictures to the thread
My moms on a disabled income and this may very well be the only tv she can afford for awhile. Id really like to get it working again
Originally posted by R_J View PostSo when you try to turn on the tv, and it does NOT turn on you have +13 volts ?
There are a couple other voltages like the standby AL+3.3V
and P-ON+21V
I believe the 12 volts is actually AMP+13V
Is this a BA3AU0F0102 3 power supply board?
I could be way off base here but isnt it not normal to have all the voltages on in standby mode?
Edit also my p on is 5 v not 21!?
The pinout is on the picture. Sorry for the bad handwriting. I was rushed lol
Main
Tcon
P-Board
P-Board Pinout
and P-ON+21V
Is this a BA3AU0F0102 3 power supply board?Last edited by R_J; 05-18-2019, 10:01 PM.
