LG 50PA550 - No picture (95% of the time), has sound.
  • acklac7
    • Apr 2019
    • 3
    Greeting all, trying to repair my mint-condition, dumpster-recovery LG 50PA5500 for the second time. First time around it was a high-pulse capacitor on the main power board, this time i'm a little stumped...
    Symptoms: TV slowly but surely started displaying no picture, but always has sound. At the point now where it will only display a picture 1/75 times I power-on. Once it powered on it will display a picture for days.
    Interesting observation: If the room temperature is below 50 degrees, and the unit has been powered off for more than 4 hours, it will initially display a picture 90% of the time. Again, once the display comes on, it will stay on for days. You turn it off a minute after you get it to turn on? It acts up and won't display a picture for hours and hours.
    Figured it was the caps, but the caps don't look all too bad? Maybe some ever so slight bulging on a few, but nothing eureka-inducing.
    Thoughts?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: LG 50PA550 - No picture (95% of the time), has sound.
    Pictures of your tv and hoards help us help you.
    • Nick's Tvs
      • Jan 2014
      • 621
      Check for cracked solder joints on your power supply Y-sustain and Z-sustain. Those can and will cause the symptoms you are experiencing.
      One thing you can do to rule out your main board however, is to remove the main board from circuit completely and jumper the auto exe gen holes together. If the color pattern test comes up no problem everytime then main board is at fault. If you are unable to get pattern test then main board is not causing the fault.
      • Nick's Tvs
        • Jan 2014
        • 621
        • acklac7
          • Apr 2019
          • 3
          I've reflowed cold soldier joints before with pretty good success on various automotive applications. Guess i'll give it a shot.
          Will post pics when I decide to turn the TV off, probably going to be a bit.
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ex250
            Kenwood SW-505D no sound issue and pops from time to time when it works
            by ex250
            Hello mates,
            I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
            It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
            12-29-2024, 03:27 PM
          • Exim
            ASRock N100M, no picture no boot, but semi-alive
            by Exim
            Hi guys,
            I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
            ASRock N100M special features:
            - CPU soldered to board, small Intel 12th gen
            - iGPU
            - four POST LEDs
            Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
            I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
            Symptoms:
            - no picture/signal on any of the display connectors,...
            04-01-2025, 02:36 PM
