LG 55EC930V OLED - 3 Second Power No Display
  • freakaftr8
    replied
    Re: LG 55EC930V OLED - 3 Second Power No Display
    The reason you're getting a dim picture is because DRV_ON is enabled. However there is no data being fed to the panel. The fact that you don't have any white vertical lines Is a good sign because these OLED'S love to burn vertical tabs.
    Those buttons that are on the main board do a reset of the tcon, And the other resets the TV as if you were to unplug it and plug it back in.
    The system is very finnicky and super sensitive to any over voltage condition of the panel. If it recognizes a gate failure it will shut down. It will attempt to restart 2 consecutive times before a lockout condition occurs. This is sensed by T con board. You're no picture is most likely and invalid T con board with a wrong panel ID number for the panel. (This happened to me until I installed the OEM tcon back in.) Also if the tcon came from a smashed panel it could have shorted blowing a fuse or an inductor.
  • Diah
    replied
    you need now to start from beginning trouble shooting. but after you put all changed you did before such-
    1- put the original Main board , put the original T-CON driver. then turn on and see the result same as the photo you posted before. use your app to press Menu to see if there OSD come out . also freakaftr8 suggested feed it with signal like blue ray at HDMI IN which labeled with ARC so the TV will switched to this input.
  • freakaftr8
    replied
    Btw. Try your original tcon.
  • freakaftr8
    replied
    By the way guys sorry I haven't been on the forums lately. I really have a lot on my plate these last few years..
  • freakaftr8
    replied
    So the LG logo is staying lit without any jumpers in place? It seems to respond by pressing volume up volume down and input buttons? I can see you are getting some kind of a picture can you put something into an H DMI port to produce sound or go to TV mode to produce static sound?
    Also is the TV shutting down after a period of time going to the blink cycle?
    This particular set up if not getting acknowledge that everything is systems go then after 3 consecutive power UPS it will go to the lockout
    Sorry for the PM.. Didn't realize you were in the UK
  • Billsy
    replied
    Ahh I see. Yes after initiating power only mode the power will stay on and if I unplug then plug in, it will power again.
    Trouble is, I can't get any further than the partial dim screen. It doesn't respond to any remote comands
  • Diah
    replied
    Originally posted by Billsy
    Diah sorry but how can you tell it was going into STB mode?
    Whats SM? Safe Mode?
    Apologies but I don't understand the second part of your post.
    Thanks for your help tho I really appreciate it.
    BR
    this TV before you received it was at STB mode before they plug it out from wall socket..each time you was try to plug it on.. it goes to the last state -- your case was STB... this option at all TV can be changed at SM service menu.
    also when you turn it on with IR that's enough it will turn on always after you plug it at wall socket
  • Billsy
    replied
    BR
  • Diah
    replied
    also your TV was going to STB mode after you plug it at wall socket AC. as its in SM as original set to remember last state.
    now when it is on don't turn it off with IR. keep it so easily, also i assume your Original T-CON will have same way to show on your panel. so its not as you tilled 3 Second Power No Display
  • Billsy
    replied
    Ok so I pulled the tcon from the cracked set, loaded it into the other set and no change.
    After hours of pi55ing about with IR leds and headphone cables trying to make a IR blaster, found an old galaxy tab in a cupboard with an IR blaster built in. Anyway long story short, using the RCoid app, I was able to send the Power_Only command and the TV powers up. The screen is very dimly lit kind of across lower left corner. I'm guessing this is now out of lock out mode but this is as far as I can get. The only other thing. There are two buttons on the main board. Does anyone know the procedure to bring it back to life or am I wasting my time?
    Many thanks
  • Billsy
    replied
    I just got an identical set for £80 on ebay with a broken screen. This should be fun!
  • Billsy
    replied
    Originally posted by Diah
    if i am i will change this board.
    Yeah maybe I'll look out for a replacement board.
  • Diah
    replied
    Evss_con_ out
    From different angle
    this LG suffer from Panel burned image, because of the discharge problem, and this parts i mentioned its belong to discharge, to me its over heated .. let hear other opinion
  • Billsy
    replied
    Evss_con_ out
  • Diah
    replied
  • Billsy
    replied
    Here's the back side
  • Diah
    replied
    EVSS_CON_ out driver IC burned
    replied
    Could you take a picture of the bottom side of the board? Curious about something.
  • Billsy
    replied
  • Billsy
    replied
    Rest of pics are rotated by the forum for some reason.
    Thanks guys
  • learnmore
    Lg oled 55ec930v automatically turns off after 1-2 seconds
    by learnmore
    Hi Community,
    I've got the above model that activates the relay (clicks) and powers on the LG logo power light on when turned on. It then almost immediately turns off. I not noticed any image on the screen or heard any sound during this brief period.
    Checks show:
    3.5v on SMPS on (in off state, no other voltages present incl pwr on)
    On pressing power button > the 3.5 pwn on voltage, 12v and 24v lines appear on the SMPS connnector between the main the SMPS but then all drop the zero in 1-2 seconds
    Disconnecting 24 to TCON connector and powering on shows...
    05-08-2024, 02:42 PM
    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 04:30 AM
    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 07:12 AM
    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:40 AM
