LG 50PT350 bad lower y buffer
  • shiz1
    • Dec 2018
    • 5
    Recently received an older lg plasma for free to fix.
    Symptoms - no picture but i have sound. I hear the click of the relay, and the hum from the ysus.
    What i've tried - i remove the ysus buffers one by one, when i removed the lower buffer i get picture on the top half of the screen. Removing the top buffer and leaving the bottom still gives me a black screen.
    i tested the va/vs at the psu and they're within spec as outlined by the sticker.
    I tested the lower buffer checking continuity between the white connector - see attached pics - on the buffer and the connectors that attach to the fat wide ribbons on the side. I get continuity at one of the ICs.... so im assuming the lower buffer is toast.
    Im uncertain how to proceed to test to check if the damage spreads to the the main ysus itself or if its localized to the buffer.. There has to be a reason why that lower buffer is toast....i'd hate to buy another lower buffer, install it then blow it again...
    any help would be appreciated
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 50PT350 bad lower y buffer
    It does look as though it would probably only require the lower buffer to be replaced. Having half a screen displayed would suggest the necessary voltages are OK.
    See what others more experience forum members have to say.
    • shiz1
      • Dec 2018
      • 5
      anyone?
      • shiz1
        • Dec 2018
        • 5
        Hey guys, so i replaced the Ysus board...the issues still persist (still waiting on a lower buffer).
        However i tried to measure the VSC Vy and im not getting any readings.... I have it set to DC v...but i get no reading when i measure across the resistor for either the vy and vsc on the Ysus
        Am i just measuring it wrong?
        • R_J
          • 9624
          If the buffer board is removed You won't be able to measure the VSC voltage across the resistor, If I remember, you might be able to measure a voltage at the VSC point to ground but without the buffer board there is no voltage drop across the VSC test points (resistor).
          • shiz1
            • Dec 2018
            • 5
            Ahh good to know. Im assuming the same would apply if your board is pooched.
            Ill re-measure once the new board comes in hopefully that resolves the issue
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • legg
              LG 42PC3 buffer output doesn't follow YSUS
              by legg
              LG42PC3D -UD originally with green lamp but no display or audio.
              Owner says was working, then went 'pop'.
              All 5V caps bulging. replaced.
              All PSU output voltages within spec but -Vy is low on YSUS.
              One of three parallel fets between SUS_OUT and SUS_DN is zenering,
              eventually shorts DG. Replaced all 3 - -Vy now OK.
              Y scan buffer test point does not follow YSUS output below -50V
              Note: This unit seems to expect YSUS output to park at -Vy in between
              drive signal pattern periods. A replacement drive signal board confirms this....
              11-18-2021, 11:49 AM
            • Yanleb
              Schematic or datasheet for Plasma TV buffer chip
              by Yanleb
              I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
              So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
              Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
              05-18-2022, 01:36 PM
