sony kdl-40r470b Restart
  • krishnu2092
    • Dec 2018
    • 5
    • Malaysia
    This tv was given to me by a friend. It turns on well and i'm able to use for 2-3 minutes before there's a hissing sound, and it restarts. i've disconnected the speakers and the noise seems to be coming from the pcb.
    I noticed that the caps had been leaking and there's traces of electrolyte on the pcb. I'm not sure about the value of the capacitor. Can anyone help me?
    I managed to pull this pic off the internet. These are the caps.
  • davidebeatrici
    Sony M851 MBX-217 no POST and restart loop
    by davidebeatrici
    Before proceeding with a component level repair, the usual troubleshooting process was followed:
    1. Disassemble and unplug everything except the power connector.
    2. Replace RAM.
    3. Replace CPU.
    4. Rewrite BIOS.
    Unfortunately the board was still stuck with a 0.75A power consumption at 19V.
    After reflowing both GPU and north bridge in one shot (it can't hurt) there was an instant improvement with a constant 1.75A power consumption, but I immediately noticed smoke and the typical smell coming from the GPU area.
    I thought to myself "Well,...
    07-03-2025, 04:19 PM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • shouri
    Dell latitude e5490 auto restart
    by shouri
    Hi guys, can someone help me?
    I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
    Board model is dm70 la-f401p rev:1.0 2017-09-20.
    At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
    After a few days test, is seems ok.
    Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
    12-10-2024, 09:27 PM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
