Lg 42pg60ur
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Lg 42pg60ur
    Hi Guys, could any one help with my LG 42PG60UR.
    All the input ports excepting the Hdmi ports work.
    When selecting source, all the available ports excepting the hdmi ports are displayed.
    I have a second hand board that i salvaged from another set that I will go & try on my call-out, and see if it solves the problem.
    I saw another post today on badcaps that i might be able to unblock the hdmi ports using a sequence of key presses.
    anything else i could try?
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Re: Lg 42pg60ur
    Hi again, some thing I didn't mention was that the hdmi source (lap top) did work on another tv, so the source is okay.
    • bobbyskillz
      • Dec 2010
      • 76
      Re: Lg 42pg60ur
      Try toggling Simplink off if it's enabled.
      • Grunder
        • Jan 2016
        • 323
        • south africa
        Re: Lg 42pg60ur
        Thanks Bobby, will check that out on next visit. I have seen a couple of samsungs turn their audio off when connecting hdmi, and you have to toggle the anynet off.
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Re: Lg 42pg60ur
          Had bad luck with fitting the salvaged main board. All the sockets were good bar the one for the front controls. (3 pins too many). so couldn't test.
          As for the "1105" code to crack the hdmi not displaying. It did bring up a menu with various setting changes with yes/ no options. Hotel mode was "no", and the other settings were not selectable.
          Once you selected hotel mode "yes" the other settings became selectable.
          one setting was SOURCE, and was set to "no"
          Source was set to "yes" & hotel mode back to "no"
          It kept source at "yes", but didn't solve the problem. (i even tried unplugging mains to make sure it booted from cold)
          I've set all back to original, and will pick up another board from a friend. Last attempt
          • Grunder
            • Jan 2016
            • 323
            • south africa
            Re: Lg 42pg60ur
            Unfortunately returned hdmi unrepaired
            • DynaxSC
              GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
              by DynaxSC
              I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
              There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
              The board is generally working now, all PCIe ports are working, Windows installs normally.
              However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
              The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
              03-10-2025, 12:27 PM
              Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
              09-06-2024, 09:40 AM
