Free DVD player from a scrap TV/DVD combo!
  • lookimback
    • Aug 2013
    • 1489
    I've had a couple of these sitting on my bench for months (maybe years). I had noticed one of the connectors had Pb, Pr, and Y, which refers to component video, and thought that someday I'd see if I could make it work as an external DVD player. Someday came, finally. I chose this particular one because it only needed 5v. The other needed 5v and 12v, but that one also had the ability to be turned off, so that's probably better. My decision was based on the idea of powering it from the USB port on the TV, and if that didn't work, I had a cell phone charger rated for 2A@5v. The USB port idea worked, but on this TV it stays powered even on standby. It's actually the service port and I think on a TV with USB as a media option, it would be turned on and off with the TV. I had no clue what this came out of when I started. Now, thanks to the splash screen, I at least know it was a Coby. I noticed it had a pin labeled IR, so I wired up some random IR sensor I had in my junk drawer. As far as the wiring, I just wired it up to some A/V cables I had laying around. I tried all the universal remote codes available for Coby DVD players, and TV/DVD combos for a couple different universal remotes. I was able to get a few functions to work, including FF, RW, and zoom, but not with the correct keys on the remote. I also noticed a few connector locations which have no connectors. Not sure what they are for, but I am thinking they may be for function keys. I guess my options for getting the remote to work are as follows:
    A) Try to figure out what TV this came from and buy the original remote for it.
    B) Figure out how many bits the remote codes are and brute force every possible combination.
    C) Hack the firmware and remap the functions to some remote I already have.
    A is probably the easiest, but that's only if the TV's main board doesn't receive one code, and transmit a different one to the DVD unit. I don't know how this was configured in the TV.
    B would require writing some simple script to try a code, and then increment, but I would need some way of detecting if something happened. Considering that a 12 bit code space would have 4096 possible combinations, I certainly wouldn't be able to sit there and watch for responses. But, if the script could somehow log all the codes which did get some response, I could then go through them and identify the respective functions.
    C would be my preferred way, just because it seems like more fun, but my recent experience with trying to hack TV firmware tells me that it may not be an option at all.
    So, for the moment, no viable remote option. The good thing is that it has play, stop, and eject buttons on the control board. I really only did this for fun, but since it works I'll probably use it for testing inputs on TV's I'm repairing.
    ------------signature starts here------------
  • nervous_capybara
    Repairing the Hitachi DA-6000 CD player
    by nervous_capybara
    Hello everyone !
    I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
    Feel free to share your experience if you ran into other issues.
    DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
    CD tray would not come out of the player
    I could hear a motor spinning inside the player but the CD tray would not come out.
    Turned out that the issue was the CD tray belt that aged poorly and began to...
    11-05-2025, 03:11 AM
    MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
    This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
    09-06-2024, 05:30 PM
  • cstout
    DeLonghi AC Remote only accepts 3V
    by cstout
    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
    I can't find any schematics...
    06-03-2024, 03:53 PM
  • Mc_Millian
    Toshiba 50lf711u20 fire tv remote not pairing
    by Mc_Millian
    I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
    The Tv model number is: 50lf711u20 Rev B.
    I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
    I've tried 3 different remotes which should be fully compatible with this TV.
    Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
    The power button, along with the volume,back,select, and directional...
    04-07-2022, 12:15 PM
  • edugimeno
    HiSense 55A7500F won't obbey to remote after power on
    by edugimeno
    Hi! I have this TV set that does the following:
    1) I press the red power button on the remote
    2) The TV turns on normally
    3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
    4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
    Then after it's off, it would again accept the TURN ON from the remote and same again
    BUT:
    -The remote does show the correct IR beam while observed thru a phone camera
    -The TV works fine while using the MiRemote...
    03-14-2023, 11:22 AM
