Samsung Syncmaster
  • mojo_tsi
    • Sep 2018
    • 6
    • austria
    Samsung Syncmaster
    Hi there,
    i am currently fiddling with a samsung monitor/tv combo.
    Backlight cuts out after about a second, picture seems fine otherwise.
    1. I touched up some suspect solder joints especially at D109 wich seemed to be quite toasty give the color of the PCB
    2.Tested some caps in circuit and desoldered some but ballpark numbers seemed okay(device used was the M-Tester)
    3.Measured resistance on the inverter transformer, very low ohm on the primary and about 1.3k ohm on the secondaries.
    4. No idea what to do know, probably measure voltages on the live board, wich i kinda wanted to avoid...also i got no spare CCFL..
  • R_J
    • 9535
    Re: Samsung Syncmaster
    Can you hold the back of the tv up to your monitor so we can read the model number?
    Or just post it.
    Try disconnecting one of the ccfl plugs, does the backlight come on for a second, if yes, recoonect it and disconnect the other one, that should tell you if the ccfl is ok (but could still be bad)
    What is the BN44-????? number on the board and also the ccfl drive ic number if you can read it
    • mojo_tsi
      • Sep 2018
      • 6
      • austria
      I thought i had the model in the thread title.
      Model: P2770HD Type No.: EM27TS
      Model Code: LS27EMDKU/EN
      There is a Top and a Bottom CCFL assembly, each containing 2(?) Lamps
      The CCFL's both shut down after 1s no matter wich one assembly i disconnected, so no new information there.
      The PSU-Board BN from the service manual i found online is BN44-00322A, found a pic of a spare board for sale that also had the discoloration around D109 so i think the BN number is correct.
      • mojo_tsi
        • Sep 2018
        • 6
        • austria
        IC wise i found three on the underside of the power PCB.
        Biggest one reads: SEM2105 1026
        • mojo_tsi
          • Sep 2018
          • 6
          • austria
          Just measured the voltages on the low voltage side(main board) 5V rails where at about 5.1V, 14.5V was only at 13.28V.
          Maybe this is another P2770HD where the TM-09210 died?
          The coil resistance was okay, and there where no discolorations but i guess i'll order the transformer and try.
          • R_J
            • 9535
            I checked the other threads and one said they measured the 14.5 as 13.?? so its likely normal. The only other schematic I found that used the sem2105 was for a BN44-00251D.
            Seems theTN-09210 fixes a lot of the backlight problems so it could be bad, one shorted turn is all it takes and that will not change the dc resistance at all
            • mojo_tsi
              • Sep 2018
              • 6
              • austria
              Fixed it, thank you!
              The voltage stayed at 13.x, even with new caps and an new TM-09210.
              The new TM-09210 had about 986 Ohms resistance on the secondary instead of 1.4k but the backlight is back so i wont complain.
              Since i switched the caps & the TM at the same time i cant be 100%, but i'd guess the TM was bad.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                I would tend to think the TM-09210 was the problem.
                  09-07-2024, 05:50 AM
                • mikey5791
                  Help on Samsung Syncmaster T220 dead ccfl lamp
                  by mikey5791
                  This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                  Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                  10-18-2020, 03:17 AM
                • soopacrucial
                  by soopacrucial
                  Hi folks,
                  10-29-2024, 02:40 PM
                  09-06-2024, 11:40 PM
