Samsung LE-40A656
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Samsung LE-40A656
    Hello all forum members, I've just purchased a Samsung LE-40A656, the picture seems ok, apart from it looks like the picture sometimes speeds up? or is this normal?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung LE-40A656
    What program source are you using? If it is an on-line source like NETFLIX or other then it could be that your WI-FI is slow and so when it starts again the picture has jumped or sped up to the current time frame. Post a video clip of what is happening, so we could actually see what you are referring to. Thanks
      09-07-2024, 05:50 AM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • Dodgethis
      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
      by Dodgethis
      Hello all,
      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
      09-11-2024, 07:39 AM
    • YellowJacket
      Samsung QE55Q60RAT - no picture
      by YellowJacket
      Hi friends,
      a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
      07-30-2024, 01:31 PM
