Mainboard TP.MS338E.PB803 need software via usb
  • viktorkane
    • Jul 2018
    • 32
    • albania
    Hello all
    please i need firmware for Mainboard TP.MS338E.PB803 via usb
  • yohnsee
    Semi-noob
    • Dec 2017
    • 198
    • Hungary
    Re: Mainboard TP.MS338E.PB803 need software via usb
    here you go. Didn't mention the display type, this one is for V420HJ2-P01.
    Cheers, Janos
    • viktorkane
      • Jul 2018
      • 32
      • albania
      yes Mainboard TP.MS338E.PB803 firmware via usb
      DISPLAY LC320TUAP00
      TV ELKOS MODEL 32LR221 AD-S
      • yohnsee
        Semi-noob
        • Dec 2017
        • 198
        • Hungary
        DISPLAY LC320TUAP00
        Try this one. Unzip, put the 3 files on a thumb drive, and hope for the best.
        Cheers, Janos
        • viktorkane
          • Jul 2018
          • 32
          • albania
          Hello friend
          is the same mainboard but vary display
          should fit and and display
          • ened_azomi
            • Jan 2017
            • albania
            I need a firmware for this mb with a 40 inch panel, can this work? How can i install it?
            • yohnsee
              Semi-noob
              • Dec 2017
              • 198
              • Hungary
              Hello.
              The exact type of the panel is there, I don't guarantee that it will work with other 40"
              You need an EEPROM writer for this job.
              Cheers, Janos
              • ARGO
                • Jul 2018
                • 31
                DISPLAY LC320TUAP00
                Your panel is HD ready (1366(RGB)x768 [WXGA]) 30 pins LVDS (1 ch, 8-bit)
                and it will not work with flash posted above because V420HJ2-P01 panel has 1920(RGB)x1080 LVDS (2 ch, 8-bit).
                • viktorkane
                  • Jul 2018
                  • 32
                  • albania
                  firmware in this main is nand flash not have eeprom
                  you are amateur or professional
                  • ened_azomi
                    • Jan 2017
                    • albania
                    There is no usb firmware?
                    • saimir
                      • Feb 2017
                      • Albania
                      HELLO
                      Electra ET-32HD17s-t2
                      DISPLAY CX315DLEDM
                      HELP WITH A SOFTWARE
                      • tomasis
                        • Apr 2017
                        • Albania
                        Hello
                        Please send me the software of Elkos Tv 32LR221 ad-s with board TP.MS338E.PB803 and display LC320TUAP00
                        • raileanu
                          • Sep 2015
                          • 126
                          Hi!
                          I am asking a lot of someone who can help me with a soft flash for usb for this Vision Touch VTTV AND32 TV with motherboard TP.MT5510S.PB803 and 1366 x 768 screen resolution which is locked in the android screen. I searched everywhere but I only found an upgrade file for usb that works wnen the tv is functional, normal software update via menu, and not the one for the procedure with the power button pressed and then connected to mains to automatically start the software update. Thanks a lot in advance.
                          • raileanu
                            • Sep 2015
                            • 126
                            Is wariant 4G. Please if someone can help me.
                            • raileanu
                              • Sep 2015
                              • 126
                              Variant 4G/8G.
                              • Bruno Pereira
                                • Feb 2025
                                • Portugal
                                Hello, I need firmware for Mainboard TP.MS338E.PB803. My TV is a Blualta BL-F32-HD
                                • PNI E.
                                  firmware hitachi 50hk6000 mainboard 17mb130s
                                  by PNI E.
                                  hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
                                  02-14-2025, 02:06 PM
                                • AustinComputerDoctor
                                  Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
                                  by AustinComputerDoctor
                                  I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
                                  I see backlite is active,
                                  but I cannot get the screen to return back to menus , etc
                                  This is all after replacing the mainboard...
                                  any assistance is greatly appreciated.
                                  03-25-2024, 12:43 PM
                                • TheUser
                                  Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                  by TheUser
                                  Hello to everyone ,
                                  This is my first post here, and i would like to share with you a small story in case you can help me.
                                  Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                  All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                  I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                  02-10-2024, 02:07 PM
                                • cheeky2
                                  Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                                  by cheeky2
                                  I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                                  Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                                  The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                                  Details:...
                                  08-17-2023, 04:34 AM
                                • gurj1979
                                  Ubiquiti firmware help. US-8-150W POE
                                  by gurj1979
                                  Hi guys.
                                  I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                  Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                  So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                  Got New chip and writes good.
                                  THE PROBLEM...
                                  It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                  Does anyone have a Good Firmware I can have?...
                                  07-22-2024, 05:13 PM
