Sony KDL--52VL150 looses signal
  • fcisolutions
    • Jan 2017
    • 205
    Have this sony television that will work great for a couple of hours and then the input (direct tv hooked up to HDMI 1) will cut off and then cut back on. Not that big of an issue but it has increased over the last couple of weeks. Tried different HDMI ports and same result. Also tried a playstation to make sure it was not my direct tv unit.
  • Diah
    • Feb 2013
    • 6599
    Re: Sony KDL--52VL150 looses signal
    be aware your Tv had the last firmware ER4.12-E3: if not then update it manually . and then after that need do factory reset.
    • fcisolutions
      • Jan 2017
      • 205
      Yes I checked the firmware it is up to date.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Cold solder joint on the Main Bd.??
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
        • kramer826
          Sony KD-55X8500F service manual BL-on signal
          by kramer826
          Hello , I am looking for a service manual or schematic information to find out where to measure BL-on signal backlight on signal from the mainboard.
          I have a tv which works fine and a spare main board that Ii am trying to fault find that is not turning the backlight on,6 flashes.
          The backlights work ok with other main board.
          Thankyou for any information
          07-14-2023, 03:50 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • mohamed mm
          sony vaio mbx-247, missing S5_ON signal
          by mohamed mm
          Hi everyone, I hope you are having a good day.
          I have a laptop sony Vaio, DA0HK1MB6E0, MBX-247. REV: E
          The laptop suddenly shut down as the owner told me, so I did the normal check there is no short but the laptop it's not powering up and there is no light when I connect the adapter because there is no battery.
          so I checked.
          pu9:
          Vin: 19v
          Ldo: 4.89v
          Ref:1.99v
          Vcc: 4.89v
          Vdd: 4.89v
          output
          3.3v pcu.
          EN2: 4.89v
          but No
          01-19-2023, 05:17 AM
