Samsung 4k dark areas
  • budwich
    • Jul 2015
    • 3097
    Re: Samsung 4k dark areas
    you still misunderstand. IF you are seeing them, they are not disconnected from the panel. If they were, they would be gone as there is nothing to keep them there. Anyways, you can likely get rid of the "dark side band" by removing all of those side tab on the "troubled side". You might get lucky and the set will be almost "perfect".
    IF you provide a picture of exactly what the side tabs look like, we can confirm this better.
    • marce002
      • May 2018
      • 316
      • Argentine
      ok i will answer when I get home. But I remember (not sure) when took apart the other day that I have removed a metal panel to expose the bottom tabs right? i touched them to allow presure looking for errors but all seemed fine.... then I ve noted that the lcd panel had tabs "floating free" at both sides not being connected to anything (I think) color brown---- are we talking about that here? they were all unconnected because I saw no board at right or left (I was always seeing the tv from the back)
      this is not my panel but here I marked in red the similar tabs that i have in mine. if needed i can take appart mine again, not problem I apreciate your help!
      Marcelo J
      • marce002
        • May 2018
        • 316
        • Argentine
        God!! I have just found this
        https://www.youtube.com/watch?v=N_HN62eDv5c
        Should I try!! what is the scienific reason this side tabs exists? will them ruin the FULL HD or 4k leaving the set in 720p? in my case shoud I also remove left side of tabs looking the tv from front of screen as stated in the video? or remove tabs from offending side, in this case right side?
        Marcelo J
        • budwich
          • Jul 2015
          • 3097
          that is the "standard save" (removal of the tabs on the bad side). Lots of posts on this group dealing with that "method". It will likely solve your "dark side issue" but it may / will not solve the "spotting" that you pictured.
          As I indicated the side tabs for this particular set "interconnect things" on the panel itself and don't go to an edge board. If you look closely at the tabs, you will see that the traces inside the "tab tape" go from one side to the other and probably pass thru an IC that is bonded to the "tab tape".
          Anyways, with their removal, the resulting picture will be "OK"... you may notice some "non-uniformity" across the screen in terms of brightness but no where near what you are currently seeing. Read up of some of the thread especially around sharp 70 in sets where this is a major problem and the only way to "save" these sets from the dump. Note: once you remove the tabs, there can never be replaced so be certain that this is your "last choice".
          • marce002
            • May 2018
            • 316
            • Argentine
            yes I understand no way to place them again, but not clear to me if
            1) only valid method for 3 tabs per side not 4... i cant remember how many i do have
            2) if 1920x1080p and 4k will still be present after removal.
            Marcelo J
            • budwich
              • Jul 2015
              • 3097
              it doesnt matter how many tabs there, thay all have to be removed on the troubled side. the tabs have nothing to do with the resolution... they are used to drive the signal towards the panel. you might see a slight refresh difference and an uneveness / slight shade across the screen during screen displays of solid colors. anyways, read / search thru the forum as suggested.
              further, I wouldn't necessarily pull the tabs with the power on. The youtube guy may have been lucky that he didn't take out the other drivers at the bottom of the panel. Anyways, as you see in the youtube video, his tv is "much better" once the tabs have been removed.
              • jetadm123
                • 2169
                #27
                Nice video, but I would not recommend you remove those tabs while the TV is turned on. Make sure you perform the tab removal while the TV is OFF.
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  #28
                  Ok... here some pics of mine (made with my S7). 6 tabs in each side. Not aparent burned or hot while turned on on any of 6.... not sure if proceed or not because seemd not burned and failure is not "flickering"
                  PD it does not have any side board , so no cable to remove prior to test. as you see tabs are directly connected to the panel
                  Marcelo J
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Originally posted by budwich
                    ITS not a LED screen... its LED backlit... the screen is an LCD based screen.
                    QFT, unless it's OLED! OLED is a new revolutionary tech that's supposed to put LCD panels, including IPS, to shame!
                    OLED is not related to LCD!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      #30
                      Samsung does not make OLED TVs. OLED is flagship to the LG brand of flat-screen TVs that do not work with a backlight but rather each Pixel is a cluster of RGB LEDs.
                      QLED on the other hand is flagship to the Samsung brand and is basically a LCD TV that works with a backlight.
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
