Emerson/Funai LF46EM4 no image
  • Josh86
    replied
    Re: Emerson/Funai LF46EM4 no image
    Originally posted by budm
    Can we see the pictures of the T-CON board?
    Attached again. Let me know if you want detail of anything and I might be able to use a DSLR to get a closer high res pic. Would it be worth checking for audio again on an input since I'm getting normal voltage to the TCon now?
    replied
  • Josh86
    replied
    There are two cables between the T-CON board and the LCD panel, try having it connected one a time to see if you will get good picture on half of the screen or not.
    Half of the panel completely white, the other half black with one connected. Same with both cables. When both are connected it looks just the same as when they are both disconnected (black screen).
    Attached main and supply board pics -- couldn't do it from wife's old iPad earlier. Attachments from photos on iOS just automatically name every file "image" when uploading and overwrites multiple files, just leaving you with the last uploaded.
    replied
  • Josh86
    replied
    BTW: 'I do not have any voltage across F1 when the TV is powered." That is because the fuse does not have open circuit (bad blown fuse).
    Yeesh, sorry, even I know better you can't get a reference to anything like that. Not thinking. I took some circuit analysis and DSP long ago but never really used it. This is about as much practice as I get...when I feel like trying to fix some broken thing a couple times a year.
    So might have to take a step back.
    I removed the TCon board for better lighting and access with my multimeter. Rung out pins (1 and 4 connected to fuse). Have 12V on pins 1 and 4 out of mainboard to end of LVDS. Hooked TCon back to mainboard and LCD panel to check voltage on pin 4. Got 12V. Checked pin 1...also 12V AND both sides of fuse read 12V now. LVDS cable isn't getting hot anymore either. Noticed the power supply board wasn't as noisy either. Wondering if a cable was not seated well or something else shorting a connection.
    Got excited and lifted up the display...but no picture still. So now I'm sitting at 12V power to TCon and wondering what to do next.
    replied
    Trace out which pin on the T-CON board side is connected to the T-CON SMD fuse and then remove the LVDS cable from the T-CON, that pin should go back to the main board whisch where you see if it has 12V or not when T-CON board is not connected.
    Right now it is either there bad circuit on the main board or the T-CON is loading down the switched 12V, it will require in-depth reverse engineering to trace out the connection tio get down to component level, I hope you do know electronics well enough to accomplish the task.
  • Josh86
    replied
    Did you verify that you do have 12V on both ends of the SMD fuse on the T-CON board?
    Upload good clear pictures of YOUR boards will also help.
    I do not have any voltage across F1 when the TV is powered. I get ~3V when I measure from either side of the fuse to the chassis and a little less to a ground on the T-Con board. I have continuity across the fuse. Everything on that board is surface mounted and I didn't see any other fuses on that board. Image attached.
    I noted that the LVDS cable feels pretty hot on the pin 1 side (unless that's normal, cable is rated for 105 C). It's not inserted backwards.
  • CapLeaker
    replied
    Also verify the LVDS cable being correct way installed not backwards.
    replied
  • Josh86
    started a topic Emerson/Funai LF46EM4 no image
    (LF461EM4) Initially this 46" LCD was shutting down on me after the Emerson logo and channel display. Through the info of another thread here I decided to look at the backlighting and found that the center row of LEDs were out (LG branded). Bought a Samsung branded replacement on eBay and it works. It no longer shuts off with a blinking front LED sequence.
    However, at some point during disassembly or reassembly of the front panel I must have done something because the display no longer shows anything. My first thought was I damaged some part of the LCD or connectors...but then I thought I should listen for audio on an input source to verify. Plugged in the audio/video RCA leads from a game console and cycled through sources (without visual) and I didn't hear anything coming through at all. The only sound change I hear is the slight change in pitch from the transformers on the PSupply board when cycling the source button. I also see my backlighting change brightness slightly when cycling sources.
    At the supply board I have what I assume is normal voltage for the 21v power on and the 3.3v standby/always on. I haven't really checked anything on the main board because I'm not sure what I should be looking for. It's definitely getting voltage though. Also I had a small crimp in my cable from main to the T-Con(?) but it's no worse the the folds from the factory. I started checking continuity on that but kinda gave up after the 10th pin.
    Initially I was just going to order a new main board but I had a a hard time finding one...which the LEDs were the primary issue anyway. Kinda back to where I started but a different problem. I see some people offer online/mail in repair services for these boards if that is the issue.
    Any advice for troubleshooting and testing would be appreciated. Hoping I can salvage it and put it upstairs as a game and movie TV for me and the kids. Sorry for the essay, I like to be descriptive and usually find that putting all the info out there helps get the problem solved quicker.
    PSupply board: BA3AU0F0102
    Main: BA31T0G02013
    Starting Serial # DS2
    And yes, I'm aware it's a cheap unreliable off-brand...but I like to fix things if it's worth it.
    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:20 PM
    HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    09-06-2024, 10:56 AM
    HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
    HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
    This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
