I cant believe Shopjimmy is finally reducing some of their prices on parts that they have many available! 'Bout time Jimmy. There are some really good deals.
WTF-Price drops?
I have a MBP A1398 EMC 2881 here, it chimes, boots and shows picture on external screen
there is an apple logo on the display, no backlit
I measured the PP3_G3H on the backlit fuse - it's 12.6V when not powered and it drops to 10.8V after startup.
Is this OK?
Also measured the LVDS connector pin 1, there is 0V, could that be the backlit driver chip?
Also checked all 4 "backlit" capacitors, all OK, not shorted.
Thank you very much,
-jp12-02-2024, 01:29 PM -
Folks, I have a Vizio flat screen that doesn't show any signs of life (and no orange vizio glow either).
I tested the voltages from the power board (at the connector) and I can see the 5V supply drops to 3V after the power cable is connected to the main board (5V supply reads as 5V when cable is disconnected from main board). All other rails (12V and 24V) are reading fine.
I looked for the usual bloated caps and saw none on either board and no other tell-tall signs (black marks, burned components, etc) on either side of both boards.
Given the 5V rail... -
by tintin_sn2I recently purchased a second hand RTX 2070 - an OEM Acer Predator manufactured by Sapphire - not a very common model.
Upon connecting it up I noticed the fan wasn't operating resulting in the card overheating and shutting down. I checked the fan operation independently by connecting it directly to a power supply and function generator - it was working correctly with variable speed according to the square wave frequency.
I then checked the output with a multimeter/DSO and verified that the GPU was putting out both 12V at pin 2 and PWM at pin 4. However, when the fan is...1 Photo -
Do you have any idea what it could be? Thanks.
by SailmanHello
I have Dell inspiron 3558 motherboard number 14216-1 Rev: A00
the laptop came dead (no boot and no lights) to me and I changed:
1- pu4503 (tps 512525)
and
2- EC (nuvton npce285)
then the laptop works but after it boot to windows the Cpu frequency drops to 0.48ghz (wont go up after that) and fan goes full speed, it also do that if I boot from Windows PE.
I tried different bios's with clear me same problem and another EC nothing changed.
both cpu and gpu are cold with this happen.
Anyone have any idea what is the problem?...
- Loading...
