toshiba 50L3400U screen blinking
  • larry708
    • Jan 2017
    • 15
    • us
    my buddy asked me to look at a tv for him and said it started blinking black and going back to display and so on.. so i had it for about a week or so but someone in my house misplaced the remote or i lost it.. either way. is there any other way to rest the settings since the tv dont have a menu button, only input, power vol up and down .
    without remote.
    i tryed to basics, holding down power button while not pluged in.. holding power on till it comes on. etc.. the tv when tested on playstation when its dimmed but not full bright like in idle mode. it dims to like half bright as a power saver, well it wont do it then. but soon as come out of idle it will start when the screen brightens back out. so my question is .. is there any other way. without remote, using computer thru hdmi, comcast remote, samsung s7 , ipad4 to get to the menu, or can i take the back off and pull the internal battery, i understand its a led light issue, just trying to see if its what the problem is since i dont have a remote to reset the settings. and what is involved in the part testing. thanks again guys.. hopefully someone ran into this same issue.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
    09-06-2024, 05:27 AM
  • Sam Scarbo
    Brother DCP-L2540DW scanner/printer - only showing blinking screen in LCD.
    by Sam Scarbo
    I got this broken printer from my brother who got it from the street. He asked me to help to fix it.
    I need help on fixing this machine.
    Issues/Observations:
    1) When connected to power, it's not working. Only showing blinking screen on the LCD. See pics 1 and 2. It is blinking every 2 seconds.
    2) I pressed the buttons on the control panel to see if there is any response. The "Options" button can turn off the LCD screen, and then press hold the power button for about 1 second can turn the blinking screen back on again. Other than...
    10-19-2023, 10:32 PM
  • sigmeyer
    Toshiba 50UL4B63DG faulty screen?
    by sigmeyer
    I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
    08-30-2025, 08:13 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
